170 manual flywheel
Invectivus
170 manual flywheel
Post #1 by Invectivus » Wed Mar 04, 2020 12:00 am
Is the 3 speed manual flywheel on a 170 the same on a falcon and a bronco? Are there different flywheels for the 170?
I have a 170 out of my falcon, and someone wants one for their bronco, and i don't want to send them something that won't work.
1967 mustang coupe - 200ci, 69 dizzy, adjustable rockers, headers and dual exhaust, T5.
1964 convertible falcon - Gutted.
1973 EB Bronco - 302ci (sorry!) DUI ignition, C4/D20, Dana 44, 33's
jamyers
Re: 170 manual flywheel
Post #2 by jamyers » Wed Mar 04, 2020 3:07 pm
I'm pretty sure it's going to depend on the year...for example a '62 Falcon is going to have the smaller 8.5" clutch and a 2.77 transmission, while a later one (67 and up?) will have a bigger clutch disc for a bigger (3.03) transmission.
James - '62 Ranchero (200cid), '71 LeSabre (464cid)
The ONLY safety device we need is a 6" sharpened steel spike bolted to the center of the steering wheel of EVERY vehicle.
Emergency Rooms and Funeral Homes will be busy for a week or so, then I predict a dramatic drop in vehicle accidents.
Econoline
Post #3 by Econoline » Fri Mar 06, 2020 11:20 am
My van had a 170 w/the 3.03 and 8.5" clutch when I got it. The 170 was a swap, came with a 144, but the 3.03 was stock. The van is a 64 and was the first year for the 3.03. I don't know the answer for the Bronco though. Come to think of it though, I don't think the 170 ever got a bigger bell, so it should be fine I would guess.
It ain't gonna fix itself
B RON CO
Post #4 by B RON CO » Sun Mar 08, 2020 10:11 am
Hi, my 66 Bronco, first year, has the large bell housing, 9" clutch, and if I remember correctly, a flat flywheel. A friend of mine was cleaning out and I saw a 144. Small bell housing pattern and small carb opening. Good luck
1966 Ford Mustang - 289 V8
Econoline
Post #5 by Econoline » Sun Mar 15, 2020 1:53 pm
This is the back of my 170. I thought all 170's used the same 132T flywheel. If his starter has 3 bolts, he will use this flywheel and an 8.5" clutch.
Patrickd07
New Member
Post #6 by Patrickd07 » Tue Sep 15, 2020 7:39 am
jamyers wrote:I'm pretty sure it's going to depend on the year isolation pour 1 euro...for example a '62 Falcon is going to have the smaller 8.5" clutch and a 2.77 transmission, while a later one (67 and up?) will have a bigger clutch disc for a bigger (3.03) transmission.
You're absolutely right. It also depends on what you want to use it for.
Users browsing this forum: Bing [Bot] and 16 guests
