C4 for a 1967 200
dmario21
C4 for a 1967 200
Post #1 by dmario21 » Tue Aug 31, 2010 6:04 pm
I recently put a 1967 200 in my 62 Falcon wagon. I mated it up to the original 2-speed Ford-O-Matic. She has plenty of power around town, but freeway and highway driving isn't much fun with that 2-speed. From what I read, I can run any C4 from a 1964-1969 small block V8 or a 200 I6 behind my 67 200, as long as I have the bellhousing for the 200. Is this correct? Next question, does anyone have a line on a C4 from a 200 or at least the proper bellhousing?
early ford fan
Re: C4 for a 1967 200
Post #2 by early ford fan » Tue Aug 31, 2010 9:30 pm
i have one.where are you?
dmario21
Post #3 by dmario21 » Tue Aug 31, 2010 9:54 pm
I'm in Queen Creek, southeast of Phoenix.
early ford fan
Post #4 by early ford fan » Wed Sep 01, 2010 6:12 pm
wrong coast.
jet471
Post #5 by jet471 » Wed Sep 01, 2010 9:47 pm
dmario,
I have one, but it needs to be rebuilt and it would have to be shipped from Mississippi.
It is a 69 or 70 c4 that was bolted to my 66 200 dual pattern block.
Jet47
62 ranchero, 66 model 200 ci, duraspark 2, t-5, new floorboards
Crosley
Post #6 by Crosley » Wed Sep 01, 2010 11:34 pm
I do not understand what a swap to a C4 will do for freeway driving? Both trans are 1 - 1 in high gear.
I have a small round bell housing for a 200 engine.
I have a C4 trans too.. 1968 unit.
Converter would need to be located for the 24 spline input shaft on my trans. I might find that too
Tony in AZ...
"130 mph is known as first gear at the Bonneville Salt Flats"
dmario21
Post #7 by dmario21 » Wed Sep 01, 2010 11:52 pm
Won't having an extra gear keep her from revving so high? I don't have a tach, but it feels like she's winding pretty high at too much past 60 mph.
I'd be interested in your C4 if it comes with the bell housing-- or at least the bell housing. I have the converter that was on the 200 when I got it, so I should be OK there.
Crosley, I see you're in AZ. Shoot me a message if you're in the Phoenix area. I'd love to talk to you about that C4 or at least the bell housing.
early ford fan
Post #8 by early ford fan » Thu Sep 02, 2010 4:37 pm
the c4 won't change the reving unless the other transmission is slipping.however a c4 has a lower first gear so you can swap a better rear gear in and not lose any acceleration.
dmario21
Post #9 by dmario21 » Thu Sep 02, 2010 10:19 pm
The 2-speed actually seems to be pretty strong. Do you think I'd get more bang for my buck by dropping a higher geared 8" rear end and running 15s in the back and 14s up front? Right now I'm running the stock 13" rims, and I haven't gotten around to changing over to 5 lug yet.
Crosley
Post #10 by Crosley » Thu Sep 02, 2010 10:31 pm
as I mentioned both the 2 speed and the 3 speed C4 are 1 - 1 gear ratio in high gear.
Sounds like you need a rear gear change or taller tires to help freeway speeds. I would spend money there first
I am located in Gilbert, AZ.. Pecos and Greenfield roads
Tony in AZ...
dmario21
Post #11 by dmario21 » Thu Sep 02, 2010 10:45 pm
Thanks for the advice. I'll start there and see what happens. We're in the same neck of the woods, so if you see a light green 62 wagon running around, it's me.
Users browsing this forum: No registered users and 8 guests
