can i use the 8.5 flywheel with the 67 up bellhousing?
early ford fan
Post #1 by early ford fan » Fri Sep 03, 2010 8:20 pm
i have a 67 bellhousing coming so i can bolt up my toploader od trans.is there any combination of parts that will allow me to keep my 8.5 flywheel annd pressure plate and use the 67 up pilot bearing and throwout bearing?if so what starter would work?i know i need a different clutch disc.
JOSH1966200
Re: can i use the 8.5 flywheel with the 67 up bellhousing?
Post #2 by JOSH1966200 » Tue Oct 05, 2010 2:15 am
well sadly if you have the small flywheel you may not be able you bolt the 67 bell to your block unless you have the duel pattern block if you do then i still thin you will have to change the clutch and fly wheel
66 mustang coupe 200 punched 30 over headers autocraft 2100 front disks 4 speed and a 8 inch posi 4:11
80 mustang hatchback 200 t5 5 speed and 2:80 gears 51 mpg highway
82 f100 swb 300 c6 9 inch rear 3:50 gears
62 ranchero 170 2:77 3 speed 6.5 rear 3:90 gears top speed is 1/2 the speed of smell
rbohm
Assistant Admin
Post #3 by rbohm » Wed Oct 06, 2010 1:06 am
8) the starter is going to be the same, and in the same location, and the flywheels are the same diameter, it is the friction surface that is different. you should be able to find a clutch disc that will work with the smaller friction surface and the top loader trans. i believe that a four cylinder T5 disc will work but check first to be sure.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
Frankenstang
Post #4 by Frankenstang » Thu Oct 07, 2010 12:13 pm
I'm not 100% positive, but I believe the 8.5" flywheel w/132 teetch gear is going to come up short inside a 67 bell. IIRC the OD of the 8.5"/132 is like 11-1/8" while the OD of the 9"/136 is closer to 11-13/16"
-Robert
66 Mustang 200+30, 67 BH, 89 4cyl T-5, 71 Comet 4 lug 8" 3:1rear, 85 T-Bird v6 DS, 10 Mallory Unilite Hyfire VI-A, 08 Vaporizer 1bbl, 68 Cougar 2" exhuast,65 pipe, 74 Mav man disc m/c & Scarebird(87 Stanza rotors 89 Cavalier calipers), 73 Datsun 240z Appliance Wire Mags, 03 Mustang Leather seats
All in one car! Johnny Cash would be proud...I got it One Piece at a Time
rbohm
Assistant Admin
Post #5 by rbohm » Thu Oct 07, 2010 11:05 pm
Frankenstang wrote:I'm not 100% positive, but I believe the 8.5" flywheel w/132 teetch gear is going to come up short inside a 67 bell. IIRC the OD of the 8.5"/132 is like 11-1/8" while the OD of the 9"/136 is closer to 11-13/16"
8) near as i can tell, all the high mount starter bell housings have the starter in the same location, which means that the flywheels are the same diameter.
64 falcon
66 mustang
05 grand marquis
of invention
Frankenstang
Post #6 by Frankenstang » Fri Oct 08, 2010 12:55 am
rbohm wrote:which means that the flywheels are the same diameter
Could be?...I can't confirm the OD on the 8.5" gear, but have confirmed the OD on the 9". 65 and earlier BH are definitely smaller than the one year 66 or the the 67 and up to srod...66 and later being the higher/larger diam drilled dual pattern blocks, and I've only 'heard' you can't fit a 9" in the early bells where an 8.5" will fit, but have not seen it for myself.
...guess it's it's like an old professor of mine would say..."it's like the sign outside the mortuary...remains to be seen" 8)
-Robert
Users browsing this forum: No registered users and 6 guests
