Trans & slip yoke help needed
mcthirsty
Post #1 by mcthirsty » Sat Sep 25, 2010 1:42 pm
I seem to be having a really hard time finding a slip yoke that will fit my 3spd. This is what I know: It's a 200 with the manual 3spd, 25 spline, came out of a '66 mustang, has the floor shifter. I do not have the orig car or driveshaft.
Numbers on side of trans:
C40R-7006-A
W-6 D14
I got a slip yoke sent to me out of a fairlane that had a 25-spline 3 speed behind a 200, but somehow it does not fit. It is too fat in diameter to fit inside the tail housing. Did they make different yokes for different years or tailhousings?
The numbers on the slip yoke are
C20A4868D
Should I just give up and call a transmission/driveshaft shop? Jeeeeezzz... :?: :bang:
mcthirsty
Re: Trans & slip yoke help needed
Post #2 by mcthirsty » Sat Sep 25, 2010 2:09 pm
Correction: the yoke came out of a '62 fairlane with a 170.
Any info would be appreciated.
early ford fan
Post #3 by early ford fan » Sat Sep 25, 2010 3:03 pm
did you read my reply to your ad in the parts section?i have a yoke id sell but i have no way to know if it will fit your car.it came from a 62 econoline with a 170 and three speed.do you know the outside diameter of your yoke or the size of your ujoint?
mcthirsty
Post #4 by mcthirsty » Sat Sep 25, 2010 4:43 pm
Sorry, I didn't see that. I'll see if I can measure it and get back to you.
Thanks!
mcthirsty
Post #5 by mcthirsty » Sat Sep 25, 2010 6:02 pm
The one I have that I can't get to fit has a diameter of exactly 1.5". All the ones I see for sale new have 1.5 "seal diameter" which I assume is the same thing and they say they fit all early 3 speeds. :?:
1bad6t
Post #6 by 1bad6t » Sat Sep 25, 2010 6:33 pm
Maybe this chart can help you figure out what size yoke you need.
http://1bad6t.com/extra/yokesize.jpg
Jeff in Georgia
'74 Maverick 250/C4
mcthirsty
Post #7 by mcthirsty » Sat Sep 25, 2010 7:49 pm
Thank you, that is a great chart. It looks like they make 1.5" and 1 3/8" 25 splines. The inner seal measures slightly less than 1 3/8" so that must be it.
What vendor is that chart from, or do you know where I can buy a yoke? Thanks again.
1bad6t
Post #8 by 1bad6t » Sun Sep 26, 2010 8:37 am
I forgot where the chart came from but any driveshaft shop should be able to hook you up with the correct slip yoke.
Jeff in Georgia
'74 Maverick 250/C4
early ford fan
Post #9 by early ford fan » Sun Sep 26, 2010 5:18 pm
1bad6t wrote:Maybe this chart can help you figure out what size yoke you need.
i have number five on that chart.
mcthirsty
Post #10 by mcthirsty » Sun Sep 26, 2010 5:24 pm
Great - I'm definitely interested. Please email me at sfohare@hotmail.com
Thanks!
Users browsing this forum: No registered users and 8 guests
