t-5 granada
79granada
t-5 granada
Post #1 by 79granada » Tue May 01, 2012 5:45 pm
thinking about putting a 5 speed in my granada 250 with a jatco automatic. anybody have any ideas what it would take to do this
'79 granada 250 inline six 80,000 miles (gone)
'96 ranger 2.3 4cyl 5 speed
'96 chevy blazer 4x4 4.3 v6(wifes car, im trying to talk her into a ford)
'86 F-150 300 inline six automatic rust free 97000 miles
MPGmustang
FSP Moderator
Re: t-5 granada
Post #2 by MPGmustang » Tue May 01, 2012 6:52 pm
a t5 is a manual trans, are you looking for a 5 speed auto? any auto that bolted to the v8 will bolt to the same bell as the 250 as the 302 shares the same bell.
if it's a younger trans, you might need a computer to control it.
65mustang-SOLD-200ci-t5-scarebird disks-vintage air ac-264/274 110 cam-mav 8inch 3.8 open-350cfm-CI headers
66 Bronco-SOLD-i6 170 - rust bucket never ran...
75 bronco-SOLD-v8 c4 dana 20 33's and disk brakes, locker front/rear.
79granada
Re: t-5 granada
Post #3 by 79granada » Wed May 02, 2012 8:18 am
yeah im looking for a manual just wanted to get an idea of the clutch linkage/pedal set up
Re: t-5 granada
Post #4 by bubba22349 » Wed May 02, 2012 4:52 pm
:hmmm: There were some Granada's and Monarch's that used a top loader trans 3 sped plus O Drive, so a factory brake & clutch pedal set, and linkage were made.
CoupeBoy
Re: t-5 granada
Post #5 by CoupeBoy » Wed May 02, 2012 6:01 pm
I'd be on the lookout for anything that vintage that had a manual.. Maveric, Comet, Granada... and if none of those pans out, start examining clutch pedals out of other cars (mostly for pin to pedal distance) if you can get the pedal to hang about the same height off the floor as the brake pedal you should be able to use one of the clutch cable conversion kits to add the 'pull' to the top of the pedal.
-ron
67Falconvan
Re: t-5 granada
Post #6 by 67Falconvan » Wed Jun 27, 2012 6:03 pm
The T5 is a great gearbox. i had bolted one up to a 76 2.3L Pinto way back when.
however i was warned by many to be careful with the performance modifications to the engine due the low-ish torque tolerances of the T5.
Don't want to see anyone go through the work just to munch up the gears and be left a great boat anchor :lol:
oh, for what it's worth, the T5 i had came out of a 4cyl Fox Body mustang. not sure if thats a viable option for you
1967 Ford Econoline Falcon Custom Club Wagon
1960s Ford Parts Van
2010 Nissan Titan
2006 Kawasaki ZX636
XFlow_Fairlane
Re: t-5 granada
Post #7 by XFlow_Fairlane » Wed Jun 27, 2012 9:44 pm
you might want to look at the pedal hanger out of a fox car. you will need to redrill for the different brake booster patern and might need to get creative at the column drop area but would be a possible swap.
$$$ option would be a wilwood or similar triple pedal setup....
I don't know if there are any Granada forums that might be of help?
but bell will either come from a manual trans falcon chassis car and use stock zbar linkage (will need an adaptor plate) or do a cable/hydraulic conversion and use a fox bell or aftermarket bell
Rule: Torque = Fun , Turbo's make Torque
vntgtrk
Re: t-5 granada
Post #8 by vntgtrk » Mon Apr 21, 2014 2:01 pm
Resurrecting an old thread. Just got a 77 Granada L code 250. Has an auto and want a T5. Any progress on this? The biggest headache looks like clutch actuation. Brake booster is right up against the firewall. Fox body pedal assy/quadrant?
JackFish
Re: t-5 granada
Post #9 by JackFish » Mon Apr 21, 2014 11:05 pm
Might want to search www.car-parts.com for an assembly.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
vntgtrk
Re: t-5 granada
Post #10 by vntgtrk » Tue Apr 22, 2014 10:19 am
Jack, thanks for the tip. I'll give them a try. Just have to determine hat will fit without too much fabrication.
JackFish
Re: t-5 granada
Post #11 by JackFish » Tue Apr 22, 2014 10:24 am
I looked for a Granada with a manual tranny and there are some available.
Couldn't post the search results though.
1999 Dodge Ram 2500
Users browsing this forum: No registered users and 7 guests
