C/4 build review
64falconsix
C/4 build review
Post #1 by 64falconsix » Fri Jun 30, 2017 10:31 am
Just posting for info.....after testing my c/4 build i will say the Champ converters 2,000/2,200 custom converter stalls at 2,100 rpm and really wakes up off the line performance......the Transgo stage 2 reprogramming kit eliminates the between shift flair up and shifts fast and firm......other mods were v8 clutch drums, c/6 front pump bearing and an A code servo......also swapped the green dot valve body for a 67 select o shift........motor specs in sig.......
64 falcon 2dr 200 C.I. .040 decked ,comp. 260 .440, C.I. adjustable timing chain w/ 79 log head 52.cc , offy w/ triple webers , Clifford header , D.U.I. , C/4 2,200 stall , Transgo Stage 2 reprogramming kit , 7 1/4" with 3.20 gears. NX, N2O 75HP shot.
10.29@ 61.91 M.P.H. in the 1/8th mile. 4/12/13
