Gear Change
Dr Jay
Gear Change
Post #1 by Dr Jay » Sun Jul 23, 2017 8:57 pm
As I develop my ride (78 F100 short bed) I thought I would present what I have experienced concerning gear ratios as they affect my set up.
Tires are P275 R15 Cooper Cobras in the rear
Weight is 3900lb
Transmission TOD with a .79 overdrive in 4th
Engine is a 300 with a 240 head, MSD triggered by DS2,
252 comp can, Clifford intake, 390 Holley, fuel injected type exhaust manifolds, walker Y pipe, 2 1/2 "
diameter out the back.
I went from open differential 2.74 in a Dana 44.
This setup broke transmissions and clutches over
time. My guess is all that torque banging on an
immovable ratio.
Went to a 9" open with a 3.25. Waaaay better with great highway speed. Used this for 3 yrs.
So then I dropped in a TrueTrac and took the opportunity to go to a Summit 3.70 ring and pinion
Truck is lighter feeling. Quicker (important to me!)
Motor revs free and starts from a stop elegantly. This is the best all around ratio. Motor is up in RPMs at 70mph but comfortable for long rides.
Is this the consensus for light trucks with no real truck working and towing? (Mine is lowered and a daily driver)
Blessings,
Dr Jay
1978 F100 Shortie, Lowered front and rear, 300 .030 over, 240 head, Clifford, Holley 390
252 Comp Cam, Cloyes, Fuel Inj. exhaust manifolds, MSD 6A, TOD, 9"
Re: Gear Change
Post #2 by bubba22349 » Sat Oct 07, 2017 10:31 pm
Sounds like a good combo what RPM's are you turning at 70 MPH? :thumbup: :nod:
