tranny fluid
mluck
tranny fluid
Post #1 by mluck » Sun Oct 22, 2017 9:39 am
had my car in for a little work and they said the tranny pan was leaking..i new it and was going to fix it,but winter is coming fast so i had them do it...my question is i noticed on the invoice..they used 2 quarts of multi-vehicle synthetic trans fluid..is this ok or do i need to put the type FA in it.
67 mustang 200ci. offy with 3 webers,260 cam,coated duel header,duel timing chain,mallory unilite with a hyfire 6a,alum. finned edelbrock valve cover and 3.20 gears.
wsa111
FSP Moderator
Re: tranny fluid
Post #2 by wsa111 » Sun Oct 22, 2017 10:02 pm
Should be ok.
On any rebuild with newer clutches i would use Mercon 5 which is synthetic.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, HEI dist. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
Murphy237
New Member
Re: tranny fluid
Post #3 by Murphy237 » Sat Dec 09, 2017 7:12 am
i have a 66 200 with rebuilt C4 what fluid to use >> mercon ???
wsa111
FSP Moderator
Re: tranny fluid
Post #4 by wsa111 » Sat Dec 09, 2017 2:03 pm
Check with your builder, but all new clutches & bands are compatible with Mercon 5. The cost is high cause it is synthetic.
Users browsing this forum: No registered users and 7 guests
