67 Crus- O- Matic
F6 lathead
67 Crus- O- Matic
Post #1 by F6 lathead » Tue Oct 24, 2017 12:21 am
I have a 67 F 100 with the C4\Crus-O-Matic transmission, I have not had a chance to drive the truck yet, but the cooling method that it currently uses i.e. water through the cooling system, can it be improved upon, or is it fine.
Re: 67 Crus- O- Matic
Post #2 by bubba22349 » Wed Oct 25, 2017 7:55 pm
Getting a good quality aftermarket auxiliary transmission cooler is a big improvement and will help the trans last longer. Another good idea is to install a good shift kit like TransGo. Good luck :nod:
wsa111
FSP Moderator
Post #3 by wsa111 » Mon Oct 30, 2017 9:25 pm
If you install the Transgo shift kit, i highly recommend to leave the original kickdown spring in the valve body. The Transgo spring is excessively too strong. When you floor it the Transgo spring requires so much pedal pressure you almost think you will bend the linkage.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, HEI dist. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
F6 lathead
Post #4 by F6 lathead » Wed Nov 01, 2017 10:03 am
thank you guys for the reply, have you got a supplier for the trans go shift kit?
