Which trans makes more noise?
Wesman07
Post #1 by Wesman07 » Thu Nov 30, 2017 5:49 am
Currently have a NP 435 and the trans is just as loud as my motor. Is the BG T19 any quieter??
In-lines we trust
Atmus
Re: Which trans makes more noise?
Post #2 by Atmus » Fri Dec 01, 2017 2:48 pm
The NP435 would be loud in 1st and reverse, but if it's loud in 2-4, there's something wrong with it.
1967 Galaxie 500 hardtop, no drivetrain
1982 F-150, 300I6, NP435 manual, single cab longbed
1984 F-250, 420 Diesel, C6d Auto, limited slip rear, standard cab longbed
1986 F-250HD, 460v8, C6 Auto, NP208, limited slip rear, no slip front 4wd, extended cab longbed
2013 Focus ST
Wesman07
Post #3 by Wesman07 » Fri Dec 01, 2017 4:57 pm
It's whiny is 2nd and 3rd when there is no load on it and the rpm's are above 2k
In-lines we trust
Atmus
Post #4 by Atmus » Fri Dec 01, 2017 6:40 pm
How long has it been since it's last servicing? How many miles are on it?
2013 Focus ST
Wesman07
Post #5 by Wesman07 » Sat Dec 02, 2017 2:27 pm
It got new syncros and maybe bearings around 130k. It probably has 230k on it now.
I tried the Lucas oil stabilizer and it helped some, but it's still pretty loud.
In-lines we trust
Atmus
Post #6 by Atmus » Mon Dec 04, 2017 8:55 am
Does it sound like bearing noise, or gear noise? I'm assuming gears as you said it was loud in 2-3 but didn't mention 4. Unfortunately I can't really offer useful advice beyond 'have someone look at it' as I've not had this problem yet, but that's not the normal operational noise I'm used to.
2013 Focus ST
Post #7 by bubba22349 » Fri Dec 08, 2017 6:33 pm
Wesman07 wrote:Currently have a NP 435 and the trans is just as loud as my motor. Is the BG T19 any quieter??
Never had one of the Borg Warner T19's but severial of T18's and NP435's, but I don't think there would be very much differance in loudness between any of them. The real big plus of the BW T19 though is that it's all sinc. even in granny low so for that reason I would want to use one of them if I had one and if it turns out to be quieter then that's an extra bonus also. If the bearings are good in your NP435 a couple of things you can do to lower the noise. First is spray some undercoating on truck cab floor (underneath, inside the doors, and roof) and then put some Jute padding or the (dyna mat) inside do the firewall too, plus carpet. You can use a some rubber heater hose on the shift handle to cut down on some of vibration noise too. Good luck :thumbup: :nod:
Wesman07
Post #8 by Wesman07 » Mon Dec 11, 2017 11:58 am
Thanks for the replies. I have tried some insulation which helped a lot. I still think my trans is just as noisy as my motor... which seems a bit high.
Do any of you guys have foam inside your shifter boot?
In-lines we trust
Users browsing this forum: No registered users and 8 guests
