2018 Contributors:
7 1/4 rear end options.
falcon_master
Post #1 by falcon_master » Wed Feb 07, 2018 9:41 am
Hi everyone. So like usual I've been doing some thought bout how will this rear end hold up I'll be honest I can drive stick well (learned on an 7.3L f250, that thing was impossible to stall) but I'm worried that with the constant abuse of other family members and sometimes even me I gonna blow the fragile rear end. I haven't found parts to be readily available either. Anyone have suggestions on what I could try to use. Dumb idea but on our property we have a parts car a 71 ranchero with a 351. Could I take the rear out of that. I might have to shorten axles or different tires though
Junior year high school AFJROTC cadet and car enthusiast. Likes all things ford and engines of any company. 64 falcon 2dr sedan,144CI and 3spd column shift. estimated 124,000 miles. Resurrected after sitting outside for 18 years, In process fixing for use as daily driver YouTube channel for repairs coming soon. “Old cars may break but are never broken”-RCR
The Blue Box
Re: 7 1/4 rear end options.
Post #2 by The Blue Box » Wed Feb 07, 2018 10:07 am
Seeing that you only have the 170. The rear you have should be adequate despite the reputation for being weak. However if you ever wish to cruise down the highway with out the motor screaming you ought to look at swapping rears as the 7 1/4 rears tallest gearing is 3.5, witch isnt ideal for the highway. Especially with a non OD trans
1964 Econoline with 2bbl converted 200 six
chad
Post #3 by chad » Wed Feb 07, 2018 1:27 pm
2X ^^^ !
remember the equation:
(motor) transmission (ie 'gears' - final), chunk (ie 'rear gear' - R&P), tire sz (ie 14, 15, etc).
This gives "Final Drive Ratio" (unless U have 4WD - gotta add in that transfer case gear).
Here's a cool chart:
http://www.metropartsmarket.com/rearend/ratio.html
some rear gears to consider: 2.73, 3.08, 3.27, 3.31, 3.45, 3.55, 3.73 (again Application is the answ 2 every Q...What is the end use/goal?)
All helpful, however that 'chero axle ('67 - '73) is a 'huge' & famous "Ford 9 inch" - better in the F-250 (w/a 351) U mentioned!
What's in a local junk yrd? the ford "8.8" (86-17 'stang)? Still too big? probably (I'm a truck guy) :oops:
How bout a (Granada or) Maverick ('71-3)? It might B the right width 4 ur car? another consideration (esp around cost to mod 4 ur use).(But might have a 5 lug flange 4 da tire)? But beefier...
How hi R U gunna push that motor's out put? Stock? Well, the Ford engineers (I bet their smarter bout this than us) came up w/a great solution (what's in there). There's a small amount of wiggle room, but unless U really hop it up...
A change to 1 part of the system effects all other parts, but here...I'm just wondering...Application?, again, will answ the Q.
falcon_master
Post #4 by falcon_master » Thu Feb 08, 2018 1:14 am
Thanks for the link that is a cool chart. My end goal is to have this be a reliable daily driver that I don't have to worry about to much. I won't be bang shifting the thing but I don't want to have to worry that at any shift my whole gear cluster could shed it self to bits or my rear end could blow up.
chad
7 1/4 rear end options, whatever U want - try'n match the rest of the system
Post #5 by chad » Thu Feb 08, 2018 7:14 am
if properly maintained, that thing will do fine as designed.
Any worries? take it apart, look at the shop or Haynes/Chilton manual and compaire what U have w/it.
Clean lube reassemble.
When I was starting the more experienced around me said: "All this works pretty good, noneadis is too accurate and precise except the adjustment between the teeth in the rear end (they usta use 'bluing" to ck engagement) and carb tuning (a vacuum gage, their ear, timing lght)."
Post #6 by xctasy » Sat Jun 02, 2018 6:51 am
http://www.fordmuscleforums.com/mustang ... r-end.html
xctasy wrote:"http://www.fordmuscleforums.com/mustang-pages-1965-1973/500968-limited-slip-7-25-rear-end.html"
If you look around, the 7-1/4" axle has a 2.83 to 3.20 to 4.00 crown wheel and pinion for it, and a limited slip diff Equa Lok version.
Mike from Classic in lines disussed it many years ago.
viewtopic.php?t=77267
xctasy wrote:Don't discredit the 7-1/4". In fact, if you are able to wade through the information, most axles except the 6.7/6.8 came with a limited slip diff "Traction Lok" or "Detriot Locker" option, specially so the 7-1/4".
Everywhere else but America, the old axles and cars are scrapped, and the steel and iron sent to China.
You guys in the USA have the advantage of guys the world over having a go at destroying Ford axles in hopped up Fords, and those 7.25's were pretty dang good. In the USA, everyone just grabs a junked 8" axle, and gos nuts.
The 7.25 ranks as a very underated axle. It existed becasue the 6.8 diff was very weak, and it took Ford 19 years to upgrade that little pip squeek axle to even the level of any 1962-1972 7.25 axle.
Somewhere in my 2500 picture liabary, I have a 1967 XR GT Falcon that used the earlier Round-body and later 7.25" Pickup axles in a drag racing application for 2 years.
http://img.photobucket.com/albums/v223/xecute/4.jpg
In Australia, the Falcon pickups ran a US Import open wheeler 7.25 axle for many years as the 6.7/6.8" wasn't very strong.
That 7-1/4 axle will certainly take a Four speed Toploader, 3000 pound Falcon with 4-bbl 289 which were 225 hp stock.
Then it got modified to 271 hp plus K code 289 spec, the still the open wheeler US import 4:1 ratio 7.25" axle took the pounding. 232 real hpon the chassis dyno, IIRC.
Thats about 240 lb-ft of torque. 13 second 1/4 miles.
Mike W (AzCoupe) back in 2006 was looking at the much stronger Traction Lok option Ford had from 1963 to 1967, and making a New Old Stock kit for it.
62Cometman
Post #7 by 62Cometman » Mon Jun 04, 2018 3:07 pm
X3 for getting it up and running first but from what ive been told the 7.25 rears will handle just about anything a small six will throw at it beside possibly burn outs. Ive honestly not heard of anyone destroying one personally, usually the smaller 2.77 trans goes first but and especially in the 144s case short of a high revving turbo option itll take anything that engine can put out and keep on ticking. It should be noted that parts are getting harder to find so it is worth while to see whats readily available but going to anything over an 8" while keeping a 6 in the car is likely overkill
1962 Mercury Comet 170 ci, Dagenham Trans, 2.83:1 7.25 rear.
She ain't fast but she's fun. 8)
WallytheShark
Post #8 by WallytheShark » Tue Jun 05, 2018 11:54 am
I'm restoring a '64 Ranchero- I've scrapped the dead 170 ci it came with and put in a 200 ci. The Ranchero has 3 on-the-tree manual.
I want to use the vehicle as a part-time freeway commuter and want to know what rear gear to put in it to keep the engine from screaming at 70 mph. The rear is stock currently and I'm assuming it's the 7.25 pumpkin.
Can the collective wisdom of this forum offer a suggestion(s).
Thanks!
Keith Lindsey
Blaine, WA
]W. Keith Lindsey
Blaine, WA
'64 Ford Ranchero Base w/200 ci, Phoenician Yellow
'71 Ford Ranchero 500 w/302 ci Calypso Coral
2003 Ford F-150 Lariat FX4 Supercab Blue
2015 Ford Fusion 2.0 Turbo AWD Blue
chad
should I swap out my 7 1/4 inch rear? what R the options?
Post #9 by chad » Tue Jun 05, 2018 2:47 pm
use the on-line caculators plez Ken, you'll hafta plug in tire dia, a;ong w/final trans gear, etc.
This poster has another Q...
Sorry, try:
http://www.apexgarage.com/tech/gear_ratios.shtml
'N ask ur Qs there or thru a different thread (so titled).
:thumbup:
StarDiero75
Post #10 by StarDiero75 » Sat Jun 16, 2018 3:31 am
WallytheShark wrote:I'm restoring a '64 Ranchero- I've scrapped the dead 170 ci it came with and put in a 200 ci. The Ranchero has 3 on-the-tree manual.
Thanks!
Keith Lindsey
Blaine, WA
It depends how deep you want to do with it at 70. Im turning 2600 with a 2.8 at 70 with my 200 and 3 OTT. Its not bad till 3rd, then jt gets gutless.
You're better off finding a 8" if you want a deeper gear as the pinion gears for 7.25s are like hens teeth. The lowest they made for them was 3.1 which puts you at 2900ish rpm. If you want deeper you have to go 8". Then if you do, i recommend one from a falcon or up to 66 mustang. They are drop ins with only the brakes to change out but youre stuck witb 5 lug. If you drop in one from a maverick, they have 4 lug but the axles and shafts need to be shortened.
--1965 Ranchero w/1966 200 and 3.03 column shift, 8" rear 2.8 (Yes I know the gearing sucks), 1968 1.08 Autolite 2100 with VI adapter, CRT Performance HEI.
frozenrabbit
Post #11 by frozenrabbit » Sat Jun 16, 2018 9:07 am
A Maverick 4 lug is a bolt in. Does not need narrowed. Same for a 5 lug. A '65-'66 mustang is 3/4" wider, drum to drum. Mustang and Maverick spring pads are same width as a Falcon axle, center to center.
I've got a '70 Mav 4 -lug in my '62 Ranchero with a factory posi center section. Only thing I swapped was to the wider Ranchero drums and backing plates.
I have a '66 Mustang 5 lug for my '63 Falcon, I'm going with a different backspacing to make up for the 3/4" difference. 5 lug discs up front.
I really don't think you're ever going to shred that 7-1/4" with your 170, unless you run it without gear oil.
StarDiero75
Post #12 by StarDiero75 » Sun Jun 17, 2018 3:59 am
frozenrabbit wrote:A Maverick 4 lug is a bolt in. Does not need narrowed. Same for a 5 lug. A '65-'66 mustang is 3/4" wider, drum to drum. Mustang and Maverick spring pads are same width as a Falcon axle, center to center.
I always heard it was wider. Or is it that the perches are off on the mavericks? My 66 8" dropped right into my 65 Ranchero no prob. I wouldnt mind the larger brakes though for a Ranchero as mine are the 66 Mustang brakes
frozenrabbit
Post #13 by frozenrabbit » Sun Jun 17, 2018 10:42 am
Maverick rear ends go right in, 56 1/2" wheel mount to wheel mount. Spring perches are same width center to center. Early Falcon is a 2" leaf spring, Maverick is 2-1/2" spring. Early Falcons are 56", with plenty of space in the wheel well for the extra 1/4" on each side.
Wider 4-lug Ranchero drums bolt right on to a Maverick 4-lug, but you also need to swap the backing plates. I have 9"x2-1/4" brakes front and rear. 5-lug should be swap-able as well.
I only know about round body Falcons, '64 and up Falcons and Rancheros are possibly more swap-able with Mustangs.
Post #14 by xctasy » Fri Jun 29, 2018 6:59 am
Thanks!
Keith Lindsey
Blaine, WA
chad
Post #15 by chad » Fri Jun 29, 2018 8:29 am
if avail I'd say the 320 will do it AND not B too bad on gas...
Is this an on-line co X?
62Cometman
Post #16 by 62Cometman » Fri Jun 29, 2018 11:20 am
x2 if you have found a ring and pinion set only that actually is for the 7.25 ford rears let me know ill definitely be interested 3.50 while performs excellent does not like going much faster than 60-65
Post #17 by xctasy » Sat Jun 30, 2018 4:54 am
62Cometman wrote:x2 if you have found a ring and pinion set only that actually is for the 7.25 ford rears let me know ill definitely be interested 3.50 while performs excellent does not like going much faster than 60-65
Re-read ALL of https://www.fordmuscleforums.com/mustan ... end-1.html
and https://www.fordmuscleforums.com/mustan ... end-2.html
AZCoupe was going to offer the Limited Slip Differential kit, which was a standard factory option in 1966 pickups and vans and trucks. The fact that the Australian drag racers didn't know about it in 1967 was typical of how information wasn't passed around throughout Ford world wide.
:P The Big o drag raced his 240 rwhp 289 Falcon GT Sedan with the open 7-1/4" 4.00 gear axle, when there was a factory US market limited slip axle around.
Read it again
The USA has the parts you need. You just have to persist with the request, and not get mixed up with other Chinese Whipsers of not true info.
List these down for future reference. :mrgreen:
1962-maybee 1972 7-1/4" Factory axle ratios....again.
1 )2.83:1 Automatic 200 six axle
2) 3.20:1 Common Manual 170/200 axle
3) 4.00:1( old Falcon/Ranchero pickups, Econoline trucks and vans, 170/200/possibly 240)
All US made, and also Australian supplied. Ecconlines, Falcons, some Fairlanes, from 1962-1966, then Ford USA went to Brzilian 8 and US 9" axles, with the Auusis upgrading to either B/W 7-7/8", Ford 's Brazilian Sao Palo 8", or US import 9" axles.
No 3.50"s in 7-1/4" axle form. None. Eva.
If you want 3.50's, you need a 9". 3.50 wasn't a common 8" ratio, its rare as rare can be
8" were generally 2.79, 3.00, 3.25 3.40, 3.55, 3.80, and a host of other kinds for trucks, vans and pickups.
8" Detroit Locker Positraction, Open Differentials, Trac Loc Positraction, all the same 28 spline axles as the 9"
8" Factory Ratios
1 ) 2.33:1 (250cubic inch 1969/1970 Mustang Economy gearing)
2 ) 2.79:1 (Std 8 cylinder small block Auto gearing)
3 ) 2.80:1 (Rare as rare can be)
4 ) 3.00:1 (Yukon Gear still make new replacements)
5 ) 3.25:1Common Traction Lock)
6 ) 3.40:1 Mustang II and some Pintos)
7 ) 3.50:1 (Rare as rare can be)
8 ) 3.55:1 (Yukon Gear still make new replacements)
9 ) 3.80:1 (Yukon Gear still make new replacements)
10) 4.62:1 ( old Econoline trucks and vans; Yukon Gear still make new replacements )
11) 5.43:1 (Yukon Gear still make new replacements)
IIRC, There was a Pinto listed 5.13 aftermarket axle
Some 9" Factory Ratios
2.47:1
2.75:1
3.00:1
3.25:1
3.50:1
3.55:1
3.70:1
3.80:1
3.89:1
3.91:1
4.11:1
4.30:1
BJBOZ wrote:I'm currently running a 3.2 Mustang non slip gears in my local 5 stud commercial diff installed in my round body. The good thing about the US stuff and the local Borg Warner diffs are that they are identical down to the threads on the bolts. The tallest gear set for Australian Falcons in '66 was 3.2, so the US gears of 2.83 will give it longer legs
BJBOZ wrote:Picked it up from the post office this afternoon.
I must say the gent I purchased it from in Indiana has been great to deal with. Prompt posting and he didn't ask for any more postage than what USPS charged him. $65 from US to OZ. ^::
You can see the family history of the three carriers. I dropped it into the diff housing to check. All good.
L to Right
'66 Ford OZ utility carrier ( originally 4.00 ratio)
'67 Mustang open carrier (2.83 ratio)
'65/66 Equa-lok carrier ( He supplied the longer bolts that hold the pinion gear than the standard bolts)
BJBOZ wrote:The equa lock carrier I have is 24 spline ( like all early 6 cylinder Falcons Comets and Mustangs) with 7.25" gears
WallytheShark
Post #18 by WallytheShark » Tue Sep 18, 2018 7:59 pm
Checked the tag- my '64 Ranchero has a 3.55 rear gear (I found a 2.83 to replace it with). I've put in a rebuilt 200 six to replace the 170- lots of pep with the current rear, but a highway screamer.
By the way, I also have a '71 Ranchero with a built 302- it has a stock 8" rear (someone commented that all the Rancheros came with 9" rears- nope, only if they had a big block or performance option). It has a 2.73 gear, but I'm replacing it with a 3.55 since I swapped an AOD tranny into it- more zip.
The baby Ranchero is making progress:
]W. Keith Lindsey
Blaine, WA
chad
Post #19 by chad » Tue Sep 18, 2018 9:15 pm
ck w/Yukon (as stated)
and
Grissley (can't spell, it's the bear's name).
Both R on-line.
WallytheShark
Post #20 by WallytheShark » Wed Oct 10, 2018 6:12 pm
Somewhat related- just finished putting in a new rear pumpkin in the '71 Ranchero pictured above with 3.50 gears in the original 8" housing. Made the 302 feel like it has another 100 hp. Got the rebuilt center section from Quick Performance $695.
Still debating the gear change on the '64.
]W. Keith Lindsey
Blaine, WA
Post #21 by bubba22349 » Wed Oct 10, 2018 8:03 pm
Since your 1964 Ranchero has a three speed manual trans in It, this makes it a good candidate for the real easy T5 Trans swap. And since 5th is overdrive then your 3.55 rear gears would be the perfect ratio for that combo of parts. Good luck :thumbup: :nod:
chad
'chero WB length
Post #22 by chad » Wed Oct 10, 2018 9:11 pm
WallyTS - is that '71 the same shortie as the square'n round bodies (109 inch, 2nd generation)?
Something makes it look as short (almost fox-bodied!).
62Cometman
Post #23 by 62Cometman » Thu Oct 11, 2018 4:07 pm
since i last posted here i switch to the dagenham 4 speed as well as swap to a 2.83 rear gear and it turns 2500-2600 at 70 being a 4 speed it adds that extra gear so driving really isnt that bad im positive if i still had the 3 speed it would feel absolutely gutless but im also barley making 60 hp if even that with my little 170
WallytheShark
Post #24 by WallytheShark » Tue Oct 30, 2018 1:44 pm
Hi Chad,
The '71 Ranchero was based on the '68-'69 Fairlane/Torino station wagon platform so it had a 114" wheel base- indeed shorter than the '70-'71 Torino coupes. That makes the wheel base on the Ranchero 3" shorter than the coupe.
]W. Keith Lindsey
Blaine, WA
chad
Post #25 by chad » Tue Oct 30, 2018 3:56 pm
thanks Keith,
most is in the optical illusion (angle of pic?, paint scheme?) as 3 inches isn;t much.
Thanks for the info.
:thumbup:
Also didn't realize it wuz based on the wagon (more to like).
fast64ranchero
Post #26 by fast64ranchero » Tue Oct 30, 2018 4:26 pm
You have options, some have been listed and some have not. Granada's drop in and had a 9", Mavericks had and 8" 57 58 ford wagons and rancheros 9" rears bolt right in, but the best one is a Explorer rear from 90 to 96, they all have trac loc rears and 31 spline. the center section is offset by 3". So what you do is go to your local "pick a part" and pull a 8.8 out of an explorer, and pull a short side axle out of another explorer. shorten the long side housing by 3" and add spring purches. now you have 31 Spline trac loc rear that is all Ford and any just about any gear ratio you want, and just a tad narrower than the stock rearend.
63 Ranchero,1965 Mercury Comet Convert V-8, 1978 Fairmont small six, mill'd off intake, 62-1 ET 12.332 @ 123.49 mph (gone)
Georgia200
Post #27 by Georgia200 » Fri Nov 02, 2018 9:19 pm
Lots of good info posted in this thread, here is my 02.
The 31 spline 8.8 is a great axle, cheap, easy to modify, lots of gear choices and many have traclok and disc brakes.
Another great option is the 7.5. Many of them have the same gears as the 8.8, some of them have traclok as well.
The 83-92 Ranger 7.5 is 56.5 WMS to WMS (wheel mounting surface), the 93-09 is 58.5 WMS to WMS.
The axle tube is 2.8 in so your spring plates and shock mounts work. Many had 10 in brakes.
Best of all they weigh less than an 8.8.
Being realistic the 7.5 was also in the 05 Mustang 240 hp V6 and the 99-04 193 hp V6s. It will do just fine under a 60s Ford with a 144-170-200-250 unless you are putting down some crazy numbers.
Many are using the Ranger or Explorer rear end without shortening the long side and report no problems. That means just a perch change and bolt it in. The offset is a problem on lowered cars, most use a hammer on the pan to fix that.
Another option is the Fox 7.5 rear end. Its 59.25 WMS to WMS. A bit wide for the early cars but the axles and drums can be redrilled to 4x4.5 if you want to stay 4 lug.
I want disc brakes and my stock hubcaps, so if I go 5 lug, Im using the 93-09 Ranger 7.5 with 10 inch brakes on my 67.
chad
Post #28 by chad » Sat Nov 03, 2018 12:28 am
R U located in Georgia? (I don't C it in sig or registration (ur name has it tho).
We just can't get that stuff in our "junk" yards. 10 yr old or older? - shipped off to the crusher. :shock:
May B I should ask U to search the yards 4 me to get an Explorer rear ! :lol:
(No envy emoji's available)
Users browsing this forum: No registered users and 6 guests
