T5 short shifter
sortafast
T5 short shifter
Post #1 by sortafast » Sat Feb 10, 2018 12:28 am
So I am seeing T5 shortshifters from $30 on ebay upto $300 on various sites. I have been out of the stang game for about 10yrs now. We did a T-5 swap after we got our 66 back 11yrs ago. But haven't done anything to it since. Does anyone know what short shifter kits will work with the T-5 in the 66? I can't remember much about the transmission or where it came from. I think my father in law sourced it for us. Anything I need to know? Any particular shifter to look at?
Firebolt
Re: T5 short shifter
Post #2 by Firebolt » Sat Feb 10, 2018 7:35 pm
I don't know what will work in your car, but I got one from aliexpress for 16$. It is actually very good, I'll modify it to work with over 16" stick. I believe everything can be made to fit.
sortafast
Post #3 by sortafast » Sat Feb 10, 2018 10:16 pm
Making stuff fit is no problem. Just not sure what is cross compatible or if there are any issues. with this. If I had the time I would just machine my own but alas, I think it would take more time than it would be worth.
Firebolt
Post #4 by Firebolt » Sun Feb 11, 2018 10:59 am
Isn't there two types of T5, for Ford and another for GM. If your transmission is Ford, the shifter for ford applications should work? I think I didn't understand completely your question.
Shorty
Post #5 by Shorty » Sun Feb 11, 2018 12:48 pm
In my experience with the t5 differences between the ch**y and ford versions: the differences were in the bolt pattern on the case that the bell housing bolted to and also differences between the length of the out put shaft and tail stock as well as the location of the shifter on the tailstock. I found that the shifter itself was interchangeable and I actually used the ford svo mustang shifter on a chevette t5 tailstock and a jeep comanche main housing with an s10 bellhousing because the jeep and s10 shifters were way too long.
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
Users browsing this forum: No registered users and 8 guests
