Would it be worth putting a 4 speed Mustang 2 gearbox on the 200 I6?
ibaumans
Post #1 by ibaumans » Tue Feb 13, 2018 3:52 pm
Hello,
I was wondering if it would be possible to put the Rocket/Hummer 4 speed gearbox on the 200 I6?
In Europe T5 are scarce, but the rockets are plenty and parts readily available..
What bellhousing would I need?
and so forth..
thx
Ivan
68 Mustang coupe, 200 Ci I6, rolling project.... :D
rocklord
Re: Would it be worth putting a 4 speed Mustang 2 gearbox on the 200 I6?
Post #2 by rocklord » Tue Feb 13, 2018 9:29 pm
Do you have any pictures, or websites that would show what the transmission looks like.'
Not familiar with that transmission.
Is it used with a 4 cyl or 6 cyl?
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
ibaumans
Post #3 by ibaumans » Wed Feb 14, 2018 1:02 pm
It comes from a 2.3 l 4 cilinder, 1978/80 Mustang. I got it real cheap so no loss if it is no good. It is the German e series rocket/hummer. Gearbox. No pics yet.
Regards
Ivan
Lazy JW
FSP Moderator
Post #4 by Lazy JW » Wed Feb 14, 2018 3:17 pm
ibaumans wrote:...
In Europe T5 are scarce, but the rockets are plenty and parts readily available...
The fact that you are in Belgium and this transmission is a common model makes it worth pursuing. I am not knowledgeable enough about your needs to help, but perhaps someone else will chime in here.
Good luck!
Joe
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
rocklord
Post #5 by rocklord » Wed Feb 14, 2018 8:39 pm
Guys on this forum use the 2.3L 4cyl T-5 with their 200 with no problems.
That transmission may take the torque from the our 6cyl.
I'll do some more digging to see if the transmission you're talking about is the same one
used in the United States.
Dan
Currently Own
rocklord
Post #6 by rocklord » Wed Feb 14, 2018 9:49 pm
Here's some information on the German 4speed from one of our forum members (xctasy)on another Ford forum:
http://vb.foureyedpride.com/showthread. ... difference
The transmission you're looking at was similar to the Dagenham 4 speed used in the early 6 cyl Falcons and Mustangs.
The bolt pattern on the Rocket/Hummer 4 speed gearbox may have a similar pattern as the Dagenham so it may be
possible to modify a 200 6cyl bellhousing to accept it.
Would need to have measurements of the bolt pattern and input shaft hole to see if there is any common holes with any of the 200 bellhousings.
Dan
Currently Own
ibaumans
Post #7 by ibaumans » Thu Feb 15, 2018 3:40 pm
I am getting the tranny saturday...I have a complete 78 I6 with auto torque and bell housing. So I can see what it looks
like...
ibaumans
Post #8 by ibaumans » Sat Feb 17, 2018 7:16 am
I went to see the gearbox today, unfortunately I couldn't use it. The bell housing and gearbox were cast in 1 piece. The bell pattern is also completely different.
Well no loss...I'll keep my eyes open ...
thx
Ivan
