Spring Perch
tdlund
Spring Perch
Post #1 by tdlund » Sun Mar 18, 2018 5:40 pm
Does anyone know what the spring perch width is on a 1961 Falcon?
Dragonlich1961
Re: Spring Perch
Post #2 by Dragonlich1961 » Mon Mar 19, 2018 12:37 pm
2 inches. Stepped up to 2.5 in 64.
tdlund
Re: Spring Perch
Post #3 by tdlund » Tue Mar 20, 2018 10:07 am
I should have specified. What’s the width from spring perch to spring perch?
Re: Spring Perch
Post #4 by bubba22349 » Wed Mar 21, 2018 6:59 pm
:hmmm: It should be 42 and 3/4 inches center to center however to double check that find the center point of your front spring perches and measure that distance too. Good luck :thumbup: :hmmm:
rocklord
Re: Spring Perch
Post #5 by rocklord » Fri Mar 23, 2018 9:44 am
Just curious of why your needing this measurement?
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
2017 BMW X3, 3.0L Dual Turbo, 300HP, 8-Spd Auto
tdlund
Re: Spring Perch
Post #6 by tdlund » Sun Mar 25, 2018 8:13 pm
I’m swapping in a Mustang 8.8 and was hoping to get the perches welded on before pulling the old 7.25
Dragonlich1961
Re: Spring Perch
Post #7 by Dragonlich1961 » Mon Mar 26, 2018 5:51 pm
Check your wheel to wheel measurement. I think the stang is to wide. I used an explorer rear axle and narrowed it to use passenger axle shafts only a 1/2" total width wider. And you get disc brakes to boot, if you use a 95+ axle. 94_ is drum. This is for use in a 61 chero.
tdlund
Re: Spring Perch
Post #8 by tdlund » Mon Mar 26, 2018 9:06 pm
Yeah I measured and it’s going to be really close. I have 1.25 wheel spacers on now. The 7.25 with 1.25 wheel spacers should be the same width as the stock mustang axle.
Users browsing this forum: No registered users and 7 guests
