2018 Contributors:
67 Mustang - Automatic to Manual transmission
thestang
Post #1 by thestang » Sat May 12, 2018 12:40 pm
I was trying to see if i can swap out my automatic tranny to a manual. How difficult is this and how much would it cost me in total? Where would i get the parts? What would i need?
Just a run down please because my tranny isnt doing to good right now.
chero1369
Re: 67 Mustang - Automatic to Manual transmission
Post #2 by chero1369 » Sat May 12, 2018 4:29 pm
You either have to have time OR money a few have both.
The kits are plentiful,but pricey.I did most of mine in junkyards.
Bellhousing from a 74 mustang 2 ,flywheel from a 67 mustang,t5 from a mustang W.C.1990,8" from a 73 maverick,used bellcrank system from a 62 ranchero instead of hydraulic,just had to grind a little on the throwout arm for the larger bearing.
It's taken me 5 yrs to gather this and I don't think I've got$300 in those parts.I haven't installed the 8" yet,but I'll get there.
The worst part was.for me,hanging the pedal and all.I don't fold well anymore.
chad
swap: auto to mani
Post #3 by chad » Sat May 12, 2018 8:16 pm
more:
will U be doin this ur self?
chero 1/4 miler's given U a purdy good prts list...
thestang
Post #4 by thestang » Tue Jun 19, 2018 12:27 am
Would an automatic T5 bolt right up?
thestang
Re: swap: auto to mani
Post #5 by thestang » Tue Jun 19, 2018 12:31 am
chad wrote:more:
Maybe i want something bolt on
chad
Post #6 by chad » Tue Jun 19, 2018 6:24 am
Stick w/1 thread. This is gunna get confusing.
chad
Post #7 by chad » Tue Jun 19, 2018 8:11 am
this may help - I have not watched it.
https://www.youtube.com/watch?v=3ee63dHOcTY
1st step is a good list. I've added to chero's but this is still not complete:
Bellhousing from a 74 mustang 2, flywheel from a 67 mustang, t5 from a mustang W.C.1990, 8" from a 73 maverick (is a rear end change needed?), used bellcrank system from a 62 ranchero instead of hydraulic (and fork, push rod), just had to grind a little on the throwout arm (may B this is what I mean by “fork”) for the larger bearing.
Plus the ‘peddle assembly’, mani shift linkage, starter change, pressure plate’n clutch, rod, TO bearing, pilot, xxx, xxx
thestang
Post #8 by thestang » Tue Jun 19, 2018 8:21 am
Good video
chad
Post #9 by chad » Tue Jun 19, 2018 10:04 am
sorry, that's for a 20 - 30 yr newer car...but U saw all the "lill stuff" that needs done (only 1/2 that needed on our more basic, older model).
Look round, utube is so huge now I bet there's the correct vid showin what's at stake.
Y not rebuild (make sure it's needed 1st) the C4 w/some speed components? reverse manual shift body, heavy kevlar bands, etc. It will operate like a mani, probably perform better (cept may not have an 'over drive' gear), no clutch to hassle w/or to rebuild/burn...
thestang
Post #10 by thestang » Tue Jun 19, 2018 5:28 pm
chad wrote:sorry, that's for a 20 - 30 yr newer car...but U saw all the "lill stuff" that needs done (only 1/2 that needed on our more basic, older model).
hmm where can i get the upgrade parts? or maybe another plug and play automatic?
chad
Post #11 by chad » Tue Jun 19, 2018 9:07 pm
i don't C ur add in ur sig so
car-parts dot com?
plug in add, Y/M/M 4 nother C4?
Again, make sure thisun is toast...
/OR?
kits R on-line, some 1 here may know a good/better/best vendor(s).
thestang
Post #12 by thestang » Thu Jun 21, 2018 6:47 pm
what other transmissions that can handle horse power can i use?
thestang
Post #13 by thestang » Thu Jun 21, 2018 6:58 pm
chad
is my tranny toast? what shall I do if it is?
Post #14 by chad » Thu Jun 21, 2018 9:49 pm
some use an auto w/overdrive (aod) the linked refference. The bell (bolt on part) needs 2 match ur motor.
The C4 (3 speed) is the least parasitic of the autos that fit ur car ( or of any auto out there).
Selection is (like all automotive Qs) predicated by application (what's ur needs 80% of the driving time).
Again - the Handbook & above tech archive R great sources 4 info.
:thumbup:
Users browsing this forum: No registered users and 6 guests
