2018 Contributors:
What 3 speeds are there?
Scuzzy_1250
Post #1 by Scuzzy_1250 » Sun May 13, 2018 7:06 pm
So again I picked up a 69. 240 a few months ago. Now that I got it running Im sinking my teeth into the other stuff. One of the previous owners did an auto swap. So I have a b&m floor shifter with a 3 speed behind it. I went down there to clean the years of gunk off and found this looks to be a c followed by numbers. Is that what I'm looking for to ID or a different location?
The below link is a video.
https://photos.app.goo.gl/G9So3sb5k82hoQs43
Re: What 3 speeds are there?
Post #2 by bubba22349 » Sun May 13, 2018 11:26 pm
That looks to be a C4 auto trans to further ID it look for an ID Tag (this info can tell you the actual application that trans was made for) that's held on by one of the servo cover bolts its right next to were you found the C and numbers in the case. Those Letters and numbers are the design or casting numbers. You can also ID it by the number of bolts hold on the pan and by the shape of the pan. Good luck :thumbup: :nod:
Scuzzy_1250
Post #3 by Scuzzy_1250 » Mon May 14, 2018 8:06 pm
Thanks man I appreciate the response I just confirmed it is indeed a c4. So not I get to read up on them. Thanks dude much appreciated.
