General Interest - 7 1/4" Rear Ends
Ashley47
Post #1 by Ashley47 » Thu Nov 29, 2018 9:29 pm
Whilst digging around my accumulated mess of parts I came across not 1 but 3 carriers for the 7 1/4". So I lined the up (with the Non-Locking 2 pinion from my car) for a group photo.
2 Equalocks, 1 x 2 pinion Non Locking and 1 x 4 Pinion Non Locking.
The 2 equalocks are strange creatures as one is U.S made the other Canadian. The inner dish is machined slightly different on both, the steel of the Canadian carrier is a little thicker, plus the Canadian one has an oil slinger whereas the U.S model doesn't. Both take a 2 1/2" pin for the pinion shaft which is different to the non lockings cases which take a 2 1/4" pin. The pin hole on the Canadian equalock has been countersunk possible due to the difference in thickness of the steel.
The 4 pinion case requires the 4211 C1DZ-4211-A 4 pinion kit for supporting the 4 spider gears.
Anyhow, just a bit of useless information which I wanted to share.
bmbm40
Re: General Interest - 7 1/4" Rear Ends
Post #2 by bmbm40 » Fri Nov 30, 2018 7:35 pm
Good information. You have some nice parts available.
NEXT- direct mount 2v, power brakes, rear LS, 3G, electric fan, electric upgrades, custom curved DSII, header, 31" tires
Post #3 by xctasy » Sat Feb 09, 2019 8:43 am
Wow man. Great info. :thumbup: :wow:
47 th post...was this just a co-incidence?
The subtle variant changes were possibly because the need for an Equal-lock was obviously met from other sources, Ashley.
viewtopic.php?t=71382
Post #47 by xctasy » Thu Sep 21, 2017
xctasy wrote:http://www.fordmuscleforums.com/mustang-pages-1965-1973/500968-limited-slip-7-25-rear-end.html
If you look around, the 7-1/4" axle has a 2.83 to 3.20, 3.50 and 4.00 crown wheel and pinion for it, and a limited slip diff Equa Lok version.
Mike from Classic in lines discussed it many years ago.
The link to the supplier is very helpful.
viewtopic.php?f=76&t=78193
The axle info I found on the differences in 7-1/4" diffs
viewtopic.php?t=78668
Post #4 by xctasy » Sat Feb 09, 2019 8:51 am
Is a four pinion Equalock a possibility?
https://www.fordmuscleforums.com/mustan ... end-2.html
BJBOZ wrote:Picked it up from the post office this afternoon.
I must say the gent I purchased it from in Indiana has been great to deal with. Prompt posting and he didn't ask for any more postage than what USPS charged him. $65 from US to OZ. ^::
You can see the family history of the three carriers. I dropped it into the diff housing to check. All good.
L to Right
'66 Ford OZ utility carrier ( originally 4.00 ratio)
'67 Mustang open carrier (2.83 ratio)
'65/66 Equa-lok carrier ( He supplied the longer bolts that hold the pinion gear than the standard bolts)
Ashley47
Post #5 by Ashley47 » Sun Feb 10, 2019 3:33 am
I wasn't aware of it being the 47th post. That number has followed me for years. Turning 47 as well this year.
In regards to a 4 pinion Equalock. No, the 4 pinion doesn't have a deep enough dish to hold the hub gear and splines, it's more like the conventional 2 pinion carrier and the 4 pinion only has the two holes for the pinion shaft.
