200 to 250 with a c4
Georgia200
Post #1 by Georgia200 » Sun Dec 30, 2018 11:39 pm
67 200/C4 coupe
Im trying to put together the parts for my 250/C4 swap, using my 200 C4.
The PO had a shop install a reman C4 two years ago. It only has about 1000 miles on it and seems to be in excellent condition. IDK if it is a 6 or 8 unit, I know its not the original.
I need to know what to do about:
Block Plate:
Torque Converter:
Bell: I found a local used bell, D7DP 7976 AA Will that work?
Starter: Im planning on a 3.8 starter.
Georgia200
Re: 200 to 250 with a c4
Post #2 by Georgia200 » Sun Dec 30, 2018 11:41 pm
Also, does anyone sell a plug for the tailshaft so I dont dump fluid all over the garage floor when I pull the tranny?
Post #3 by bubba22349 » Mon Dec 31, 2018 12:26 am
For the block plate you can use one from a 250 six, a 289, 302, or 351 SBF V8 all with a C4. From these same sources you can get the C4 bell housing, the one you found may work though without seeing can't say for sure. The flex plate needs to be "a zero imbalance" so get one for a 250 with C4 car application, as an example one from 250 six 1975 to 77 Maverick. Torque converter also needs to be for same C4 car application. Good luck :thumbup: :nod:
I am hunting for a cheap project car to build up. My Ex-Fleet of Sixes sadly these are all long gone! :bang: 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
Georgia200
Post #4 by Georgia200 » Tue Jan 01, 2019 6:48 pm
Am I looking for a zero or 28oz imbalance flexplate?
rocklord
Post #5 by rocklord » Tue Jan 01, 2019 7:41 pm
Georgia200 wrote:Am I looking for a zero or 28oz imbalance flexplate?
Zero imbalance flexplate.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
