Rear end that can handle mod power with the 4 lug pattern
Timmy66
Post #1 by Timmy66 » Sat Jan 12, 2019 9:03 pm
I have a 1966 mustang with a 200ci 6 cylinder I plan on turbocharging and I was wondering if anyone knew of a way to keep the factory 4 lug pattern but maybe in a better rear end that can handle the power?
“What motor is in your mustang a 302?” it’s a six cylinder “oh” I’ve had that conversation some many times ready to build a car that I can use that to my advantage because you know “it’s just a 6 cylinder”
Shorty
Re: Rear end that can handle mod power with the 4 lug pattern
Post #2 by Shorty » Sat Jan 12, 2019 9:24 pm
8.8 from an 87 thunderbird turbo coupe or 86 and newer v8 mustangs would be good to look into.
85 F150 on 78 bronco frame C6 np205 welded dana44 front, trussed posi nine inch rear. EFI exhaust manifolds into one 2 1/2" rolls on 35x12.5x15 Maxxis Trepador.
Timmy66
Post #3 by Timmy66 » Sat Jan 12, 2019 9:28 pm
Shorty wrote:8.8 from an 87 thunderbird turbo coupe or 86 and newer v8 mustangs would be good to look into.
Thanks I’ll have to look into them because I really wanting to keep the 4 lugs but not have the rear end explode the first time I get on it
wsa111
FSP Moderator
Post #4 by wsa111 » Sat Jan 12, 2019 9:39 pm
I believe the 8" out of a 70-72 Maverick has this upgrade.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
powerband
FSP Moderator
Post #5 by powerband » Sun Jan 13, 2019 7:14 pm
Unless you really need to be able to launch consistently under boost, an 8" rear should be sufficient. The early 70's Maverick 8 " is bolt-in simplicity and strong enough for most uses. . I run a Maverick 4-LUG 8" in an '61 Comet NA 250 Tri-Power and has survived plenty of full power launches. I retained the 4-LUG theme with 71 Maverick 4-Lug front spindles with a disc conversion and 65 V8 steering components. Only issue has been terrible wheel-hop remedied with Caltrac type devices on the 2" '61 springs.
'61 Comet - 3 CARBS, 4-LUGS, 5 GEARS = T5 / 3.80 POSI / Traction Devices
" Everything in my garage has a story ..."
Post #6 by bubba22349 » Sun Jan 13, 2019 9:05 pm
8.8 is a real good axle however their 4 lug axles & wheels use a different bolt spacing then your 1966 Mustang 4 lug pattern. If you want the front and rear wheels that are a match or you don't want to remachine the front hubs so they do, then the early Mavericks / Comets 4 lug 8 inch is a good match, it might be the better way to go. Good luck :thumbup: :nod:
I am hunting for a cheap project car to build up. My Ex-Fleet of Sixes sadly these are all long gone! :bang: 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
Timmy66
Post #7 by Timmy66 » Thu Jan 17, 2019 8:20 pm
wsa111 wrote:I believe the 8" out of a 70-72 Maverick has this upgrade.
My uncle owns a junk yard and has a 1970 Maverick with the 4 lug pattern wouldn’t it be the 8” the cover looks different from any 8” I’ve seen
Post #8 by bubba22349 » Thu Jan 17, 2019 8:36 pm
Yeah that's a no then, many of the very early Mavericks 1969 1/2 to 70 and maybe even some early 1971 models that had a 170 or 200 six engines used the 7 1/4 inch axles with a bolt on rear cover just like the Falcons and Mustangs. You will need to find one that came with a bigger 8 inch axle latter 1970 manufacture date, to up to the end of the 1974 models for the 4 lug 8 inch axels, starting in 1975 and to end of production they all were the 5 lugs 8 inch axles. Good luck in the hunt :thumbup: :nod:
63falcon4drwagon
Post #9 by 63falcon4drwagon » Mon Apr 08, 2019 1:00 am
ZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZZZZZZZZ ZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Last edited by 63falcon4drwagon on Mon Feb 17, 2020 12:56 pm, edited 1 time in total.
rocklord
Post #10 by rocklord » Tue Apr 09, 2019 5:08 pm
63falcon4drwagon wrote:
Timmy66 wrote:I have a 1966 mustang with a 200ci 6 cylinder I plan on turbocharging and I was wondering if anyone knew of a way to keep the factory 4 lug pattern but maybe in a better rear end that can handle the power?
"Memory Lane" says: The Pinto wagon with a V6 had a 8" 4 lug rear end.
The Pinto and Mustang II has a 4-1/4" bolt pattern, not 4-1/2".
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
63falcon4drwagon
Post #11 by 63falcon4drwagon » Tue Apr 09, 2019 11:37 pm
Last edited by 63falcon4drwagon on Mon Feb 17, 2020 12:55 pm, edited 1 time in total.
powerband
FSP Moderator
Post #12 by powerband » Wed Apr 10, 2019 11:16 am
Good to note 4-1/4" disc brake wheel bolt pattern of later 70's (Pinto/MII/Fox Body) vs 4-1/2" used on Mustangs, Falcons, Comets thru mid 70's . Available simple bolt- on upgrades for early cars like my '61 Comet use Maverick 4-1/2" 4 Lug Spindles with disc brakes and Maverick 4 lug 8" rear w/drums. Most available later 4 lug rears' are the smaller pattern and spring brackets probably need to be moved.
Image . Image . Image
frozenrabbit
Post #13 by frozenrabbit » Fri Apr 19, 2019 9:18 am
I have a '70 8" out of a Maverick with 4 lug in my '62 Ranchero. Center section is the same as any Ford 8", no rear cover.
A '70/'71 Maverick with a 170 or 200 will be 4 lug, 250's came with 5.
