Decoding This T5
Matthew68
Decoding This T5
Post #1 by Matthew68 » Tue Mar 26, 2019 2:09 pm
Can anyone help me ID this T5? All the usual online websites I check casting numbers, gears, etc don’t really give me anything. Owner says rebuilt 30k miles ago.
Tag code: 1352 260
1968 Mustang Coupe 200ci - Pertronix + Coil
Gulfstream Aqua - Interior + Exterior
rocklord
Re: Decoding This T5
Post #2 by rocklord » Tue Mar 26, 2019 4:08 pm
1352-260 1999 Mustang WC w/elec.speedometer for a V6.
1st 3.35
2nd 1.99
3rd 1.33
4th 1.00
5th 0.68
Rev 3.15
The input shaft on the 1999 V6 T-5 is longer (7.85") than the earlier 85-93 V8 & 4cyl model (7.20").
Most bellhousing adapter plates are for the shorter input shaft 85-93 T-5.
This site: http://pro-forceperformance.com/t-5_interchange.htm states that the 85-93 V-8 input shafts will work with the 94-04 transmissions and vice-versa. (V-8 and V-6).
http://www.5speeds.com/t5/
https://www.allfordmustangs.com/Detailed/349.shtml
http://www.britishv8.org/articles/ford- ... ptions.htm
Hope this helps.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
powerband
FSP Moderator
Post #3 by powerband » Tue Mar 26, 2019 7:08 pm
To use in most early applications, the input shaft will need to be swapped for typical 85-93 length and will need to match the counter shaft cluster gears. A PITA with the later trannys is the electronic speedo' sensor which I believe needs the earlier tailshaft housing position to align with outp. shaft gear location ( or expensive electronic 'converter'.)
Image .
" Everything in my garage has a story ..."
Matthew68
Post #4 by Matthew68 » Sun Mar 31, 2019 1:23 pm
Thanks guys, I'll pass on picking this one up. Appreciate all the information!
Users browsing this forum: No registered users and 7 guests
