Ford 8 inch sizes
StarDiero75
Ford 8 inch sizes
Post #1 by StarDiero75 » Mon Oct 28, 2019 5:08 pm
Howdy guys,
I just thought it'd be good to have on here a list of all the 8 inch sizes so we know what will fit our Falcon's, Comet's, Mustang's, and Ranchero's. I believe these values are Hub to hub, not backing plate to backing plate. If you want backing plate to backing plate, subtract roughly 5" i think.
65-66 Mustang 57.25 inches
67-70 Mustang 59.25 inches
71-73 Mustang 61.25 inches
77-81 Versailles 58.50 inches
74 Maverick 8" 56.50 inches
75 Mustang II 8" 57.00 inches
67-73 Mustang, Torino, Ranchero, Fairlane 9" 59.25 inches to 61.25 inches
57-59 Ranchero and station wagon rears, 57.25 inches
66-77 Bronco 9", 58 inches
77-81 Granada/Versailles, 58 inches
67-71 Comet, Cougar, Mustang, Fairlane, 59.25 inches
71-73 Mustang, 61.25 inches
64 Falcon 58 inches
67 Cougar 60 inches
67 Fairlane 63.50 inches (coil springs)
72 Ford Van 3/4 ton 68 inches
73-86 65.25 inches
57-59 Ranchero and station wagon 57.25 iches (narrowest 9" housing)
66-77 Bronco 58 inches but has 5-on-5 1/2 inch diameter bolt circle
67-73 Torinos, Rancheros, Fairlanes 59.25 inches or 61.25 inches
67-71 Comets, Cougars, Fairlanes 59.25 inches
Go ahead and post perch measurements if you know them
powerband
FSP Moderator
Re: Ford 8 inch sizes
Post #2 by powerband » Mon Oct 28, 2019 6:18 pm
Thanks Stardiero75 for the useful chart.
the 8" works for almost all the Ford Six cars. The 'bolt in' sizes for early cars are limited though . I know the Maverick PERCh location works for 61Comet - Falcon and will fit modest wheel sizes under fender.
these alternatives may need perch moved
Is the 57/59 an 8" or 9"?
" Everything in my garage has a story ..."
bmbm40
Post #3 by bmbm40 » Mon Oct 28, 2019 6:23 pm
Hey this is a great idea. I have always wanted to know what the options are.
chad
Ford 8 inch sizes
Post #4 by chad » Mon Oct 28, 2019 6:28 pm
addin up more 'stickies'...
Should it say "Backing Plate to Backing Plate" or what exactly...
Looks like axle mounting face to mounting face (wheel) due to the
"4 lug v 5 lug" comment...
So, yeah, needs lots more info: perch mount, lugs, etc~
more info = more useful
(I know, we can pull an axel. reposition a perch, even 'cut'n turn' but...
StarDiero75
Post #5 by StarDiero75 » Mon Oct 28, 2019 6:36 pm
powerband wrote:Thanks Stardiero75 for the useful chart.
The 57/59 Ranchero's are 9"s and they are the narrowest as they come. Don't they fit in easily too?
chad
Ford 8 inch width
Post #6 by chad » Mon Oct 28, 2019 6:42 pm
the guys I know R usin the 8.8...
May B an Explorer ?
wsa111
FSP Moderator
Post #7 by wsa111 » Mon Oct 28, 2019 9:06 pm
Chad, i believe all the Maverick,s have 4 lug wheel studs.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
Post #8 by bubba22349 » Mon Oct 28, 2019 9:40 pm
On Mavericks and Comets 8’s the 1975 to 1977’s (last year) all have 5 lugs. :thumbup: :nod:
chad
Ford 8 inch sizes
Post #9 by chad » Tue Oct 29, 2019 9:19 am
“...all the Maverick,s have 4 lug wheel studs.”
“Mavericks and Comets 8’s the 1975 to 1977’s (last year) all have 5 lugs.”
Oo0Oh Kaaay ! more detail for the stickie I all ways say.
As an aside (he sez) I getting a lill more inta the end of ‘our’ run – the ‘80s (Granada, Fairmont, Zepher) guy’s got a disassembled Durango here. I love the Lima, ThriftPower, and Winsor. They could all usa “less then” (the famous) ‘nine inch’ (100 – 200 ft# tq)...its nice in my bronk but doesn’t hafta B everywhere (altho I C that too).
What more do we need to post a "falcon rear axel" sticky? I don't think its assembled here (ol archive or new 'read only'). A full axel type listing would B even better. I C a few posts on the lighter, earlier (wuz it 7 or 7 1/4? inch) these rigs had, gathered in one spot would B nice...
DannyG
Post #10 by DannyG » Tue Oct 29, 2019 11:41 am
The earlier Maverick 8" rearends do have the same 4 lug pattern as the Falcon/Mustang.
I'm not sure of the cut off/changeover to 5 lugs.
DannyG
C8 block, .040 over, zero decked. Forged Racetec pistons , D7 large log head .9:4 compression, CSC 264-112 cam going in a '65 Mustang one day...
chero1369
Post #11 by chero1369 » Tue Oct 29, 2019 1:10 pm
grandbabymoma's 73 Mav. 8" 3.00 ratio,5 bolt.250 auto. drums all around.....76 disc,in a box,5 bolt.
Post #12 by bubba22349 » Tue Oct 29, 2019 3:26 pm
The 1969 1/2 Mavericks had the choice of a 170 base engine or the 200 engine these both will have a 4 lug axel but this is an intragal 7 1/4 inch axel like was used in the earlyier Falcons. In 1970 the Maverick got upgraded with stronger front spindels, brakes, plus the 8 inch 4 lug axle, the 250 six was also first offed. In 1971 the 170 & 200 engines continued on they would still have the 4 lug pattern 8 inch axle pattern that matches the older Falcons and Comets. In 1973 the 200 became the base engine when the 170 was dropped. I believe that in 1973 they dropped the 4 lug axles and went to 5 lugs too. In late 1971 (Dec.) the 302 V8 engines were first offered in Mavericks & Comets. From 1971 on all 250’s sixes and all V8's will have the 5 lug 8 inch axels through to the end of their USA production in 1977. :nod:
chad
Ford 8 inch sizes
Post #13 by chad » Tue Oct 29, 2019 6:10 pm
my lill pea sized brain is startin to get overwhelmed (dont take much).
Luv 2C something like Ryan's 'chart' expanded...may B a 3rd & 4th column?
(Yr, model, width, lugs, tq? o0OPPp - thats 5 already)
rickwrench
Post #14 by rickwrench » Wed Oct 30, 2019 4:13 am
4 lug 8" Mav brake flange. Same a Falcon 7.25":
Somebody right now is wondering...
Nope, the 5 lug 8" Mav axles do not fit into a 4 lug 8" Mav housing.
Rick(wrench)
'62 Falcon Wagons (x2), Kellison J5, V8 Alfa GTam, Corvair Corsa:
www.rickwrench.com
63falconATX
Post #15 by 63falconATX » Fri Dec 06, 2019 9:08 am
1963.5 Falcon V8, 55.625" (half year only) the absolute narrowest stock 8" Ford ever made. Measurement confirmed on the one sitting on my shop floor.
Users browsing this forum: Google [Bot] and 17 guests
