Can Granada rotors be drilled to 4 lugs?
Hot 6t Falcon
Post #1 by Hot 6t Falcon » Wed Nov 26, 2003 8:59 pm
Guys (and gals),
I know that the four-lug drum brakes can't be drilled to five lugs, BUT how about going the other way? Can Granada rotors be drilled to 4 lugs?
I have a slug of four lug wheels, but am gradually moving to a Disk brake set up. I'd prefer to keep the wheels I've got.
Any ideas?
Thanks
Dennis Schjeldahl, (say Shell-doll)
Co-Author of The Ford Falcon Performance Handbook
http://www.falcon6handbook.com
MustangSix
Assistant Admin
Post #2 by MustangSix » Wed Nov 26, 2003 9:39 pm
There's plenty of metal to drill to 4 lug, but to re-use the old wheels you would also have to turn the snout down to size. And then there's the issue of caliper clearance on the stock 13" and 14" wheels.
Jack Collins
addo
Post #3 by addo » Thu Nov 27, 2003 12:33 am
Just order a set of custom drilled one piece hub/rotors. It's easy here; guess similar in the US.
Post #4 by Guest » Thu Nov 27, 2003 7:17 am
The 4 lug disc brake kit that California Mustang sells uses redrilled Granada rotors.
FrankBoss
Post #5 by FrankBoss » Sun Nov 30, 2003 1:37 pm
In th old days I use to buy Granada rotors on my Pinto's.
I would have to turn them down to 9 inchs but they worked bearings and all.
So it will work the other way around as well.
Pinto 1974-1980
Mustang II 1974-78
Rotors will work.
Now I cant say much about the other parts working.
But you might be able to get the Pinto rotors redrilled or purchase them blank.
Buy the way the Rotors off a AMC Grimlin are the same as Pinto rotors but hey are 5 lug ford pattern.
Frank Canon
1960 Falcon 2 Door wagon *new 3.3L comp260 Cam* FrankBoss Carb adapter 5200 Holley. Duraspark 2 conversion MSD Blaster 3 coil,Altinator conversion, 8 inch rear end.5speed
Soon to have Oz 2V (found a Intake) now machining for over sized valves
1972 Pinto~ *289 Dual4's, 4 speed*
I'm always looking for Pintos or parts.
1984 Ranger *2.3L EFI IC Turbo & 5 Speed*
PintoWorks.com
65coupei6
Assistant Admin
Post #6 by 65coupei6 » Sun Nov 30, 2003 6:49 pm
Dennis, like Falcon64 said. The Cali. Mustang Kit has redrilled rotors. Checkout out my webpage at http://65coupei6.mustangindex.com/brakeswap.html for the part numbers.
...Marco
'65 Mustang Inline 200. VI (CI) Aluminum Head, Holley 350, Schneider 264/274 cam,
Headers, DSII, MSD 6A, and a whole lotta other stuff!
Build That Six With Parts From VintageInlines.com
Users browsing this forum: No registered users and 5 guests
