Good Dual MC swap instructions page?
CobraSix
Post #1 by CobraSix » Fri Feb 13, 2004 3:47 pm
I know there are some out there, but I have been unable to find them. Anyone know where some are. Dual Master Cylinder swap for early falcons and mustangs. Thanks.
Slade
Slade
My Website
My How to's
Engine: 200 CI, Oz 250 modified for 4V Holley 390CFM, DS II Ignition, 40kV Flamethrower, MSD Digital 6+
Drivetrain: Cable Clutch, V-8 T5, 8" 5 Lug Rear End, 5-Lug SSBC Front Brakes, 3.40:1 Posi
LaGrasta
Post #2 by LaGrasta » Sun Feb 15, 2004 11:59 am
Send me your e-mail address and I'll send you the ones I used.
1963 1/2 Falcon 170/C4/8" (alt, a/c, Petronix/42v coil/8mm wires, 16" electric fan, electric fuel pump, Holley 1940, K&N Harley air filter, power dual m/c, 11" disc, 3" drop, Shelby drop, white tuck/roll, Moon steering wheel, '59 Caddy tail lights, fishtail exhaust tip, shaved trim, handles, cowl, fuel, dash, 4" radius trunk/door corners, power windows, 600w iPod system)
bax
Post #3 by bax » Wed Feb 18, 2004 11:58 pm
lagrasta. i hate to impose but if you do not mind i would be interested in the same info. Again if it is not to much of a pain :oops: THanks mark mbaxter@gwi.net
CobraSix
Post #4 by CobraSix » Thu Feb 19, 2004 8:00 am
It is hosted here now:
www.kastang.net/reference.html
Slade
My Website
My How to's
bax
Post #5 by bax » Thu Feb 19, 2004 1:03 pm
Thanks that will be a big help.
Mark
mustang6
Post #6 by mustang6 » Wed Feb 25, 2004 8:59 pm
I'm following the instructions given at http://www.kastang.net/reference/Dualmcconversion.pdf (very helpful, thank you). The MC to pedal rod just fell out of my old 65 MC, but the rod in the 67 MC seems to be held in somehow, it won't come out. WHat is the trick to this?
Thanks, Scott
Scott
rickwrench
Post #7 by rickwrench » Thu Feb 26, 2004 3:53 pm
With the master cylinder held firmly in a vise, grab hold of the actuator rod and violently stir it around, while pulling. This should compress the spring ring on the end of the rod and walk it out of the cavity. Then throw that rod as far away as you can and use the old one.
Rick(wrench)
'62 Falcon Wagons (x2), Kellison J5, V8 Alfa GTam, Corvair Corsa:
www.rickwrench.com
LaGrasta
Post #8 by LaGrasta » Thu Feb 26, 2004 8:54 pm
Admittiedly, that's a tough one. Just beat the !@#$% out of it. It will come out eventually.
LaGrasta
Post #9 by LaGrasta » Thu Feb 26, 2004 9:26 pm
mustang6
Thanks for Help
Post #10 by mustang6 » Wed Mar 03, 2004 4:17 am
Thanks everyone, it took a bar through the pedal mount hole and a sledge hammer, but I finally got it out. :D
Scott
CobraSix
Post #11 by CobraSix » Wed Mar 03, 2004 5:58 am
just started mine yesterday. My push rod feel right out of the MC. IT's a good thing I replaced my MC, I had a MC that was leaking fluid into the rubber rod boot.
Slade
Slade
My Website
My How to's
ricksmol
Post #12 by ricksmol » Thu Mar 04, 2004 3:31 pm
This gives quite a bit of info
http://www.chtopping.com/mustang.html
Rick
Hybrid - MOTHRA
Fox body master cylinder and booster
Post #13 by Hybrid - MOTHRA » Mon Aug 09, 2004 5:19 pm
Can I use this out of 84 2.3 with my coupe that has monarch disks in front and the stock drums in the rear?
