2018 Contributors:
wheel frozen to the brake drum - and a solution
tom954x4
Post #1 by tom954x4 » Wed Sep 21, 2016 8:09 am
Had a flat with my '12 F250 last weekend, and after removing the lugnuts and jacking up the wheel I could not for the life of me get the wheel off. Fortunately, the tire pressure monitoring system (big :thumbup: ) gave me advance notice I was going flat and I was able to pull into a town with an air pump. A can of fix a flat ( :thumbdown: , ineffective) and a two rounds of air from the pump got me back to a tire store open on a Sunday before I went flat again and they removed it and put the spare on.
Subsequently, I learned a few tricks to get a wheel off in this situation, including installing just 2 or 3 of the nuts loose and driving forward and back a few feet and braking abruptly to loosen the wheel. I have not tried that. But I will soon, and take all four wheels off, clean up the areas where the wheel (aluminum) makes contact with the brake drum and hub and apply a light coating of anti-seize to the areas. I wish I had known that trick first !!!
1995 F-150 XL, 300-6, 4x4, ex-cab, sb, 3.08 5-speed, 2 1/2 in. exhaust w/flowmaster 50, MSDignition failed with no warning, now out, canopy, 179,000 + miles. Gone but not forgotten 1965 F-100 240 3spd lwb "the green hornet"; 1960 F-250 4x4, 223 six, 4sp with wrap-around rear window, two-tone paint, overhead camper.
Tow vehicle: 2012 F-250 4x4 6.7 diesel XLT s/c lwb
JackFish
Re: wheel frozen to the brake drum - and a solution
Post #2 by JackFish » Wed Sep 21, 2016 11:58 am
Yah the driving thing has worked for me.
With just a stuck drum, another trick that worked for me was after putting the car up on jackstands and finding the drum frozen, I put the jack under the drum and jacked the car a little bit up off the stands.
Then I bounced on the bumper and whacked it a few times.
Don't forget to put some nuts on it first.
Yup, I bought another one.
1996 Chevy Caprice 9C1 (3)
1999 Dodge Ram 2500
