2018 Contributors:
Geo Metro MC mounting options
rafaelb
Post #1 by rafaelb » Fri Nov 04, 2016 1:03 pm
I've gotten the parts to do the Geo Metro master cylinder conversion but I have a question on mounting options. Everything I've seen talks about drilling/enlargening holes etc to mount the MC but then I found this video on youtube:
https://youtu.be/QhSQK-Erd_o
where a guy uses two pieces of square tubing to both convert the hole pattern from four to two holes, but also seems to space out the booster eliminating the need to enlarge the hole in the firewall.
Anybody have experience with the second method versus the template/hole enlargement method?
Thanks!
1964 Ranchero Deluxe 200cid 4sp future Rat Rod?
Re: Geo Metro MC mounting options
Post #2 by bubba22349 » Tue Nov 15, 2016 2:23 pm
Haven't done this swap but if I was I'd do it with the adapter method. Where some people run into trouble though is mounting the proportion valve too high or not running their brake lines correctly by having loops in them. You need to be sure that the master cyclinder is the highest point and everything else is mounted below it so it gravity feeds, otherwise there will be a lag in braking until presure is restored into the brake lines. Good luck :nod:
