Maverick 14x6 5 lug
Eric m
Maverick 14x6 5 lug
Post #1 by Eric m » Wed Feb 01, 2017 7:40 pm
I picked these up for 50 bucks. I know they are ford. Think they are early 70's maverick. Fit fine except the center hole is 2.75 and the stock mustang wheel center hole is 2.5 inches. I will be relying on the lugs to center the wheels is that ok?
Re: Maverick 14x6 5 lug
Post #2 by bubba22349 » Sat Feb 04, 2017 7:40 pm
They look like they maybe a disk brake type wheel, there wont be any problems using them as is or you could also have a .250 inch spacer ring made if your concerned about it. Good luck :nod:
B RON CO
Post #3 by B RON CO » Sun Feb 05, 2017 9:23 am
Hi, X2. Many aftermarket wheels do not register on the hub, they just use the lug nuts. Be careful and the wheel will center properly. Good luck
1966 Ford Mustang - 289 V8
Eric m
Post #4 by Eric m » Sun Feb 05, 2017 9:31 am
Thanks. I got the steel wheels so I can still use my wire wheel covers on the mustang only with wider tires.
