ford transit 1981
paul81mk2
ford transit 1981
Post #1 by paul81mk2 » Tue Sep 03, 2019 5:23 am
brake up grade without the fertiliser... have installed ford territory 2017 booster and master .. brake lines by Adelaide brake services (behind yam pitmans) will take some measurements . drilled two holes in mounting bracket. some welding (very minor) would put up pic . but not tech savvy
Re: ford transit 1981
Post #2 by bubba22349 » Fri Sep 06, 2019 4:41 pm
What did you install those parts on? As far as posting pictures it's fairly easy, you will find all the info in the below link. Good luck :thumbup: :nod:
Post Pictures
viewtopic.php?f=47&t=48863
paul81mk2
Post #3 by paul81mk2 » Fri Sep 13, 2019 3:14 am
1981 British built , aussie modified postie van. we imported these threw out the four cyl put 250cui 6cyl
paul81mk2
Post #4 by paul81mk2 » Fri Sep 13, 2019 3:35 am
paul81mk2
Post #5 by paul81mk2 » Fri Sep 13, 2019 8:01 am
ford 250 cast iron crossflow
Users browsing this forum: No registered users and 7 guests
