Bonding on Quarter Panel Skins
1966Mustang
Administrator
Post #1 by 1966Mustang » Fri Dec 11, 2015 11:05 am
My upcoming winter project is to replace my quarter panels and outer wheelhouses.
I think I've finally decided on qp skins and bonding them on with panel adhesive. My reasons for skinning this cat are that the top beltline and top sheetmetal of the original quarters are fine and I didn't want to go through messing with the sail panel area and my perception of additional work that involved.
Here's what I'm working with so far. I have some trimming to do.
Here's a good informational video that explains a lot about using this adhesive.
https://youtu.be/CRpHgxV9260
I'm pretty sure I know what to do with the outer wheelhouses - fit everything loose and manage a happy wheelhouse to quarter skin relation before any gluing and welding takes place.
- Perry
'65 Mustang Coupe, C4, DUI, CompCams 260, Addco 1", StreetOrTrack Front Bilstein Coilover System, Bilstein Rear Shocks, 4-1/2 leaf springs.
Support our forum:
Like us on Facebook, watch us on YouTube, Buy FordSix Gear , Make a Donation!
powerband
FSP Moderator
Re: Bonding on Quarter Panel Skins
Post #2 by powerband » Fri Dec 11, 2015 8:30 pm
With careful application , bonding adhesive can work well. I was encouraged by the fiberglas teardrop scoop I 'bonded ' onto the 61'. I wanted to relieve underhood temperatures with headers and considered it might crack with the temp' cycling but has endured for a few years. This year I 'experimented' with only bonding- no welding rear quarter's on another of my cars, a Miata I hit with the plow truck two winters ago :roll: .
Using cheap re-pop panels , lapped the seam using SEM panel adhesive (and SEM 2X1 gun) and used waterproof (DynaGlas) and then regular (Rage) final filler for simple clean finish before hi-bild primer and epoxy.
Image . Image . Image .
Image . Image
" Everything in my garage has a story ..."
1966Mustang
Administrator
Post #3 by 1966Mustang » Sun Dec 13, 2015 12:55 am
Ahhh you make it sound easy-peasy, which is very encouraging. BTW, the temps here are in the 70s / 60s next week - I think it would be a great time for you to plan that getaway to Virginia Beach!!! Bring your tools! I got the beer.
But in all seriousness, this really does seem like the way to go for this application.
Thanks,
Perry
Support our forum:
1966Mustang
Administrator
Post #4 by 1966Mustang » Fri Dec 18, 2015 7:19 pm
Here's a good write up on the process I'm going to basically emulate.
Advice Installing Quarter Skins
The finished result looks like nothing happened - now I need to get to work on my outer wheel houses... but I guess I have to clean the garage to make some workspace first.
- Perry
Support our forum:
Post #5 by bubba22349 » Mon Apr 18, 2016 10:59 pm
:hmmm: so Perry did you happen to get those quarter panels glued on yet? Good luck :nod:
CoupeBoy
Post #6 by CoupeBoy » Thu Jan 19, 2017 11:25 am
Perry, did you ever do this?
After I picked up the 1965 Mustang Parts car back in 2015.
Last Fall, I picked up a pair of Scott Drake Quarter Panel Skins.
I called locally and the autobody supplies stores carry 3m or Fusor products. I'm thinking about buying the 3m supplies (applicator and 2 part bonding compound) from the internet and going that route.
The articles I've read makes it look like this is the way to go, less heat (no welding/grinding), less concern about panel alignment for the welds since the panels will overlap using this process.
1970 170/C4
1967 200/C4
1975 250/flexplate
1975 300/flywheel
1966Mustang
Administrator
Post #7 by 1966Mustang » Thu Jan 19, 2017 4:47 pm
Nope. I'm still over-thinking it... :hmmm:
So my thoughts were that - in my case at least. a combination of welding and gluing would be the best route. Plus - I made my cut about 2-2.5" below the bodyline and flanged. I kept back from the door pillar about 2" - the thought there being to butt weld... It's all fitted, but I haven't started welding. Primarily because I need to seal and paint before it gets closed up.
I will post a new picture of where it's at. The only real difference is that the outer wheelhouse is replaced and the quarter is fitted...
Coming Soon! Summer 2017!!!
Support our forum:
