2018 Contributors:
Rear windows, 60’ Comet 2door
Spaceage60
Post #1 by Spaceage60 » Thu Nov 16, 2017 3:18 pm
The rear windows roll 1/2 way down, both sides. Is this a safety feature? I’m replacing all the weather stripping so the doors are apart to remove the old. (After the new paint job of course)
There is a 3rd leg off of the window regulator that moves horizontally as the glass is rolled down..is this the culprit? :?:
Thanks!
Re: Rear windows, 60’ Comet 2door
Post #2 by bubba22349 » Sat Nov 18, 2017 3:48 pm
:hmmm: That doesn't sound like its right but do you have any pictures?
powerband
FSP Moderator
Post #3 by powerband » Sat Nov 18, 2017 8:29 pm
With the 2 door Fal/Coms, the rear wheel well prevents the window from retracting all the way down:
When I did all the window channels on my '61, I found the replacement window channel for the rubber fuzzy below the window opening on the rear side of the front door did not meet the channel frame on the window opening. The original rubber insert had metal reinforcement but the replacement was all rubber/felt.
I had to weld a piece to join it to the upper channel in the opening:
