(62 Ranchero) Remove door by removing hinge pins only?
62Ranchero200
Post #1 by 62Ranchero200 » Wed Mar 14, 2018 11:39 pm
Greetings Ford Six Fans,
I would like to sand and repaint the inside areas of the door not covered by the door panels, but with the door mounted, it would be very difficult to avoid getting overspray in the interior. Is it possible to remove the door by removing the hinge pins, such that when putting the door back on after painting, it wouldn't need any adjustment?
Thanks,
Bob
62 Ranchero, 252 cid, 300 rods, RaceTek pstns, ARP mains bolts & studs, balanced & blueprinted, CI AL head, 1.6 adj rckrs, Smith Bros, 274/274/108 cam, CI int, Holley 500, DSII, CI SS hdrs, PowerMaster strtr and 1wire alt, Optima, V8 rad, T-5z, 10" organic clutch, 5 lug 8" w/3.80 Trac Loc, rear drums, front 5 lug discs, Centerlines. Next: ?.
Re: (62 Ranchero) Remove door by removing hinge pins only?
Post #2 by bubba22349 » Thu Mar 15, 2018 1:16 pm
Knocking out out the hinge pins is a hard way of doing that job. Some pro body men after getting all gaps and lines right will drill a 1/4 inch pilot hole through the both hinges and the door then you use a pair of 1/4 inch pins or drill bits to line the door back in it’s perfect position. Good luck :thumbup: :nod:
