2018 Contributors:
Need help getting my stock ac
Scuzzy_1250
Post #1 by Scuzzy_1250 » Sat Sep 08, 2018 5:53 pm
I'm missing a fitting, I'm not sure what it is or anything living in phx AZ I really want to get it working. Under dash passenger side I guess going into the heater core?
Also I rewired my truck and now I the blower motor isn't working I don't have a diagram for the ac system. Can anyone help?
Specs
1969 f100 240 l6 2wd
Pictures in the link
https://photos.app.goo.gl/Tgi9YmfSS5aSbw9p8
B RON CO
Re: Need help getting my stock ac
Post #2 by B RON CO » Sun Sep 09, 2018 11:11 am
Hi, not sure what is missing to connect the a/c hose to the evaporator. The blower motor should be on a fuse in the fuse box. I should work any time the key is on. Check the fuse box and blower motor plug with your test light. Good luck
1966 Ford Mustang - 289 V8
Post #3 by bubba22349 » Sun Sep 09, 2018 3:23 pm
Try NAPA auto parts for the fitting look for the data plate on your unit for manufacture info IE is it a Ford installed unit or aftermarket one. Good luck :thumbup: :nod:
Scuzzy_1250
Post #4 by Scuzzy_1250 » Mon Sep 10, 2018 11:40 am
I actually bdont have a data plate one of the previous owners took it off.
Maybe a dumb question but do they redistribute them or repop?
Post #5 by bubba22349 » Tue Sep 11, 2018 12:51 am
I would think they can be found both used or a new reproduction from from many company's that supply restoration parts
F100 series truck parts (LDS?) or even one of the many Mustang supply houses as the Ford units were used in many models. Good luck :thumbup: :nod:
