Welding around undercoat
powerband
FSP Moderator
Post #1 by powerband » Mon Feb 10, 2020 7:54 pm
My current '66 project includes rear torque box and spring hanger repair. A problem involved is heavy tarry undercoat . Suggestions appreciated how anyone's dealt with it for panel/subframe repairs.
I've used bonding as well as stitch welding for panel repairs and structural subframe/spring works best with good clean weld surfaces.
thanks
" Everything in my garage has a story ..."
Re: Welding around undercoa
Post #2 by bubba22349 » Sun Feb 23, 2020 2:44 pm
I have found that scrapping or using an air chisel to get off the heavy part of the under coating can work well, depending on the type undercoating and how hard it is. Next use a wire brush head on a drill or better yet a auto body grinder, then use lacquer thiner or Acetone for a final clean up. Good luck :thumbup: :nod:
