4 lug 8” rear end
johneo
4 lug 8” rear end
Post #1 by johneo » Thu Mar 12, 2020 9:35 pm
Hello,
Looking for a 4 lug 8” rear end from early 70’s Maverick or similar.
Have a 65 Mustang and planning to do a T5 swap.
Any advice or support is greatly appreciated.
Thanks,
JO
Georgia200
Re: 4 lug 8” rear end
Post #2 by Georgia200 » Thu Mar 12, 2020 11:07 pm
Where are you?
johneo
Post #3 by johneo » Sat Mar 14, 2020 3:57 pm
Evans, GA, next to Augusta
DannyG
Post #4 by DannyG » Fri Mar 20, 2020 1:33 pm
Keep an eye out on Craigslist . I found mine by asking a guy that was listing a bunch of Maverick parts. His response still cracks me up, " My friend, you are in luck, I just removed one with 40,000 original miles on it" . It's in my 65 Mustang now, very easy install ( watch out for the 3" axle u-bolts to wrap around the tube).
DannyG
C8 block, .040 over, zero decked. Forged Racetec pistons , D7 large log head .9:4 compression, CSC 264-112 cam going in a '65 Mustang one day...
rocklord
Post #5 by rocklord » Mon Mar 23, 2020 1:01 pm
I found a 5-lug 8-inch from a Maverick and had the axle flanges/drums redrilled for 4-lug. A decent machine shop should be able to do this.
An advantage to this is I'm able to use the larger brakes from the V-8, even rear discs if I redrill the rotors.
If you don't close off the original stud holes, you can switch to 5-lug in the rear just by moving the studs over.
Hope this helps.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
Georgia200
Post #6 by Georgia200 » Tue Mar 24, 2020 9:14 pm
Johnsons Salvage in Griffin GA has a Maverick with a 4 lug 8 in.
Give them a call. (770) 227-4244
johneo
Post #7 by johneo » Tue Mar 31, 2020 4:58 pm
Georgia200 and rocklord - thanks for the info and my next stops are craigslist and calling Johnson’s Salvage. The leads are greatly appreciated.
