CI head, 250 block, pistons, rods, etc - Lower Prices
bluestang65
Post #1 by bluestang65 » Mon Nov 28, 2016 1:54 am
Selling off my build... lots of pretty cool stuff here...
250 rods reconditioned, 250 crank turned 10/10 with bearings...250 block bored 30 over (exactly .030 over, not .032 as is commonly done would need final fitting to any pistons other than the ones below) $1000
custom racetec pistons with 1.600 compression height but otherwise stock press fit forged pistons $500
CI head drilled for ported fuel injectors and custom made fuel rail, yella terra roller rockers, CI intake, ARP studs... $2800
Located between Seattle and Portland near I5 but will ship at buyer's expense.
fast64ranchero
Re: CI head, 250 block, pistons, rods, etc
Post #2 by fast64ranchero » Sun Jan 22, 2017 1:26 am
PM's you.
63 Ranchero,1965 Mercury Comet Convert V-8, 1978 Fairmont small six, mill'd off intake, 62-1 ET 12.332 @ 123.49 mph (gone)
bluestang65
Post #3 by bluestang65 » Thu Feb 09, 2017 11:12 am
Dropping the prices
The block including the Racetec pistons, timing chain, oil pump, bearings, turned crankshaft, oil pan, etc is $1000 + shipping
The head bored for injectors with fuel rail, intake, CI valve cover, '66 style valve cover if you want it, Yella-Terra 1.6:1 roller rockers (new), head gasket, ARP studs, 4bbl carb adapter for intake, and a stainless steel header (new) for $2500.
All prices do not include shipping from Olympia WA. I work all over the Pacific Northwest and could potentially meet a serious buyer in Portland or Seattle, but not someone who just wants to look.
The header or the intake will need a little clearance to work together, but the package should have an amazing sound.
da66stang
Re: CI head, 250 block, pistons, rods, etc - Lower Prices
Post #4 by da66stang » Fri Feb 10, 2017 12:15 pm
My lord this is tempting. Do you have pics of the head and intake?
bluestang65
Post #5 by bluestang65 » Thu Feb 23, 2017 3:55 pm
I don't have a pic of the header or valve cover right now. It's the same stainless steel header everybody sells... classic, scott drake... etc.
Valve cover is new in plastic.
Header, rocker arms are new. Head could use a resurface as shown, but just to clean up
rwbrooks50
Post #6 by rwbrooks50 » Fri Mar 31, 2017 9:40 pm
Interested. Sent a PM.
Rick
65-coupe
Post #7 by 65-coupe » Mon Apr 03, 2017 8:37 pm
Was the block line honed, everything balanced, any ARP bolts or studs used for the rods or main caps
1965 Mustang coupe, Poppy red with black interior, I6, DUI, CI alum head ported, 264/264 110 Clay Smith cam, 1.65 roller rockers, Autolite 2100 300CFM, Lokar pedals and throttle calbe, Spectre air intake. Shelby mod to front suspension, CI headers stainless with Jet-Hot ceramic coating, CI Stainless 2" impostor dual exhaust, 17x8 Coys C-67 wheels,
rwbrooks50
Post #8 by rwbrooks50 » Sat Jul 15, 2017 11:58 pm
I am ready to buy. Tried to send PM but, they are still in my outbox.
Rick
214-673-8086
rwbrooks50
Post #9 by rwbrooks50 » Sun Jul 16, 2017 10:17 pm
If anyone here knows how to get in touch with "bluestang65", please have him read his PMs.
I am ready to buy; but, have loss contact with him.
Please Help.
Rick Brooks
