Cylinder Head, Rocker Shaft and Push Rods, Carb and Linkage
revherbel
Post #1 by revherbel » Tue Sep 19, 2017 11:03 am
So I have completed the swap to a converted head with larger valves and 1.6 rockers (noticeable bump in power--very noticeable--if anyone's considering). That means I have some stuff for sale. Everything listed here was fully functioning and operational when removed (in June). I just don't need it any more. The VW commuter is what it is, the truck is a V8, and the future classic we're shopping for will be a V8 also. So, time to sell the following:
1) Cylinder head (1969 if I remember correctly--larger 1v opening, anyhow): $100
2) gas pedal and linkage from firewall to the carb (this came out of a 1963 Comet) $50
3) carb spacer with PCV port for the stock 1v, including fuel filter that's nearly new (just the way it timed out) $40
4) stock 1v $75
5) rocker shaft assembly and the rods to go with it $75
All items are located in Fargo, ND. If you would need things shipped, shipping costs would be above and beyond agreed to sales price. I'd have to find boxes as necessary as well, so if you need it shipped, you may need to give me a day or two to find a box or two. I will be driving to Minneapolis/St. Paul and Kansas City at different points this fall and winter, if you prefer to meet me and make an exchange then. My wife and son will be making a short trip to St. Louis in October as well.
Matthew68
Re: Cylinder Head, Rocker Shaft and Push Rods, Carb and Linkage
Post #2 by Matthew68 » Fri Sep 29, 2017 7:52 pm
Is this off a 200 or a 250?
1968 Mustang Coupe 200ci - Pertronix + Coil
Gulfstream Aqua - Interior + Exterior
revherbel
Post #3 by revherbel » Wed Oct 04, 2017 9:19 pm
Oh, sorry. It's all off a 200.
falconcritter
Post #4 by falconcritter » Fri Oct 06, 2017 9:14 am
Can you post a pic of the rocker assy ? I might be interested . Thanks , Critter
1969 Ford Falcon 2Door and future home for an Australian 250 2V , 2013 Ford F-150 Single Cab
Mkshamong
New Member
Post #5 by Mkshamong » Thu Oct 26, 2017 10:09 pm
If you're planning on a trip to Kansas City, I would like to buy that 200 Head
revherbel
Post #6 by revherbel » Sat Oct 28, 2017 7:52 pm
Mkshamong,
I sent you a PM. I'll be there in a couple weeks. I can easily bring the cylinder head along with.
Falconcritter, a few pics are here:
https://herbelgarage.wordpress.com/2017 ... wn-begins/
Mkshamong
New Member
Post #7 by Mkshamong » Sun Oct 29, 2017 11:05 pm
Revherbel,
I did receive your PM but am not allowed to reply, I will text you on the 11th to try to find a place to meet.
Mkshamong
revherbel
Post #8 by revherbel » Sun Nov 05, 2017 9:09 pm
That sounds good! I'll bring the head with me. I'll tell you which motel to meet us at. Looking forward to meeting you and hearing about your project.
ssg66stang
Post #9 by ssg66stang » Tue Dec 12, 2017 3:18 pm
Are there any parts that you are still trying to sell?
revherbel
Post #10 by revherbel » Mon Jan 22, 2018 6:20 pm
I just PMd falconcritter about the assembly. I PMd another member about the spacer.
However, I have only sold the cylinder head at this time. I still have everything else yet.
revherbel
Post #11 by revherbel » Fri Feb 23, 2018 12:08 am
Carb spacer has now been sold. That leaves only the rocker set up and the 1v carb and stock linkage for the pedal to throttle.
Matthew68
Post #12 by Matthew68 » Fri Feb 23, 2018 11:01 am
revherbel wrote:Carb spacer has now been sold. That leaves only the rocker set up and the 1v carb and stock linkage for the pedal to throttle.
Is it a stock rocker assembly or is it the 1.6? If 1.6, I'm interested...
revherbel
Post #13 by revherbel » Sun May 06, 2018 9:50 pm
Stock. I put the higher ratio 1.6 on my new rebuilt and modified head, but the what's left is the stock rockers.
Users browsing this forum: Baidu [Spider] and 1 guest
