Performance 200 cid bottom end
falcon fanatic
Post #1 by falcon fanatic » Mon Jun 04, 2018 11:29 am
$500 plus shipping
This bottom end has about 10,000 miles on it. Recommend thorough inspection before installation, but was running well and had good oil pressure when removed.
Features:
Balanced crank, rods, pistons
Align bored crank journals
Dual roller timing chain with adjustable cam timing set (https://www.vintageinlines.com/product- ... -170-200ci)
Clay Smith 264/274 - 12* cam
Oil through lifters/pushrods for use with Yella Terra full roller rockers (easy enough to replace with standard lifters if using conventional rocker assembly)
Stock dished pistons
Custom baffled oil pan
Note: This motor made low idle (5” to 8” vacuum at idle at 5200’ elevation at 14* advance) with 52cc chambers. Recommend double checking cam degree for 4* advance, and/or installing with smaller chamber head.
'63 Futura Convertible. Disc/drum, Bilsteins, beefy swaybars, #480 springs, roller or spherical everything up front, HD shackles on stock springs out back. Megasquirt FI on ported, big valve aussie head w/ roller rockers; 10:1 6000rpm engine; 264/274-12*; C-4, Maverick 8" 3.25 W/trac-lok and perimeter frame inside the unibody. More to come...
http://falconfanatic.blogspot.com/
Matthew68
Re: Performance 200 cid bottom end
Post #2 by Matthew68 » Wed Jul 04, 2018 9:00 am
Any pictures?
1968 Mustang Coupe 200ci - Pertronix + Coil
Gulfstream Aqua - Interior + Exterior
PDXfalcon
New Member
Post #3 by PDXfalcon » Sun Jul 15, 2018 7:54 pm
Where are you located?
wsa111
FSP Moderator
Post #4 by wsa111 » Sun Jul 15, 2018 8:12 pm
PDXfalcon wrote:Where are you located?
He is located in Boulder, CO.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, duraspark II dist. with MSD-6AL. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
