Timing gear set, Comp Cams 3224, 300-6 New/never installed
broncr
Post #1 by broncr » Fri Aug 24, 2018 5:03 pm
New in Box,unused, Comp cams timing gears for 300-6. Cam with a cam lit, I already have near new gears & don't need these. $50, OBO
'82 FSP Bronco. Just about every mod ever mentioned. ( Too much to list - or remember...)
pmuller9
Re: Timing gear set, Comp Cams 3224, 300-6 New/never installed
Post #2 by pmuller9 » Sat Aug 25, 2018 10:30 am
What does the bottom picture of an adjustable roller chain drive set fit?
broncr
Post #3 by broncr » Sat Aug 25, 2018 11:48 am
I have no Idea. It's just the generic picture they chose to put on the box, I presume. As the add say's - "...item may vary".
It shows retainers, too, which weren't included...
pmuller9
Post #4 by pmuller9 » Tue Oct 02, 2018 9:55 pm
Do you still have the Comp timing set for sale?
broncr
Post #5 by broncr » Wed Oct 03, 2018 8:44 am
yes
edit: sale pending
broncr
Post #6 by broncr » Thu Oct 04, 2018 12:17 pm
Full disclosure - The box shows signs of some shipping mishandling so I had a very close look and came across a minor imperfection on the cam gear. At first I thought it was a chip, but closer inspection shows that it is more likely a casting imperfection.Image The crank gear appears to be fine.
Let me know if this is unacceptable, or if you just want the crank gear...
pmuller9
Post #7 by pmuller9 » Thu Oct 04, 2018 2:07 pm
That's OK.
Ship both gears
broncr
Post #8 by broncr » Mon Oct 08, 2018 9:05 am
Watch for Brown Santa on Wednesday.
