Custom Spring to Raise WOT Shift Points in Drive C-4 Trans
wsa111
FSP Moderator
Post #1 by wsa111 » Fri Sep 07, 2018 2:35 pm
I have designed a spring that will raise WOT shift points in drive on a C-4 transmission.
It replaces the stock secondary spring in the governor.
It will be necessary to lighten your secondary piston in the 12 grams to 14 grams weight.
Only the spring is supplied.
The cost is $20.00 which includes shipping to the USA.
I accept paypal or USPS money order.
PM me or email amblerrace@live.com
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, HEI dist. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
