FAQ/Links.
SuperMag
FAQ/Links.
Post #1 by SuperMag » Sat Sep 04, 2004 11:23 pm
We don't have a truck FAQ, so I thought I'd start this sticky as a means to keep all the good info at the top of the charts. PM me with links you think should be included here... SM
Everything Dana:
Info on the D44, D60, D61... http://77cj.littlekeylime.com/web_rs44.html
Gears, Trannies, T-Cases... http://www.motivegear.com/
Gears, rebuild kits... http://nationaldrivetrain.com/shopsite_ ... age14.html
Truck & Bronco Parts:
Dennis Carpenter... http://www.dennis-carpenter.com/trucks.php
Jeff's Bronco Graveyard... http://www.broncograveyard.com/
LMC Truck... http://www.lmctruck.com/
National Parts Depot... http://www.npdlink.com/
Obsolete Ford Parts... http://www.obsoletefordparts.com/
Tranny ID & Info...
Novak... http://www.novak-adapt.com/knowledge/tr ... ateway.htm
Motive Gear... http://www.motivegear.com/tech_info/tra ... guide.html
Decode your VIN...
70-80... http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Or, you can download the appropriate catalogue from this link... http://www.broncograveyard.com/cat/?PHP ... a5516bfc95 ...the VIN decoders are at the back of the catalogues.
'67-'72 Truck resource:
http://www.fordification.com/
Yakk
Post #2 by Yakk » Thu May 26, 2005 11:46 pm
SM, you can add these and delete this post:
There's a treasure-trobe of info:
Dana Axle Information
ZF information at RockLand Standard
Rockland Standard Transmission Info
-Jackson-
5.8 Van... 4BT on the Horizon.
SuperMag
Post #3 by SuperMag » Sat May 28, 2005 9:11 am
Nah. I'll let you get the credit. (Excellent links... :thumbup: )
Also, for you guys into modifying your rigs and wheeling, I bring you this... http://www.pirate4x4.com ...I strongly urge you to check the "Tech Dept" link...
"...and he that hath no sword, let him sell his cloak and buy one." --Luke 22:36
Ferris Bueller
Post #4 by Ferris Bueller » Sat Oct 07, 2006 3:13 am
REAR BRAKE LINES, PLEASE READ:
Looks like 80 to at least 93, the F150s have 3/16" fittings going to both wheel cylinders and the right side of the fitting at the brake hose that comes down from the frame. But on the left side it uses a fitting thats one size bigger. When replacing lines on the axle you will need an adaptor fitting or a special brake line that some parts stores sell. Don't get stuck at the shop doing the lines on your only vehicle when you are 5 miles from the parts store.
White 09 Ranger 2wd 2.3 5sp 143hp 3.73 60k miles
White 04 Ranger 2wd 2.3 5sp 143hp 3.73 134k miles
Ferris Bueller
Post #5 by Ferris Bueller » Wed Nov 22, 2006 12:47 am
AXLE SPRING PERCH SPACING:
On my 85 F350 crew cab dually with a dually pickup box, 45" center to center.
On my 83 F350 "chassy cab" dually, 40.5" center to center.
On my 87 E250 van 49.25" center to center.
broncr
Post #6 by broncr » Thu Dec 07, 2006 10:11 am
'82 300 Bronco: a Borg-Warner T-19 (from an 87 F-250 6.8 diesel) was the easiest, straight-up, swap that I've done. It should work on all '80-'86 manual 300 Broncos.
I had a BW T-18, with the non-synchro 1st gear. The close ratio T-19 gives you a more functional (& synchronized) 1st gear. The CR is around 4:1 in 1st, but I understand that a ~5:1 and ~6:1 may also be found.
The T-18 & 19 appear identical ( & thus the easy swap), except that the T-19 has a PTO cover on BOTH sides.
'82 FSP Bronco. Just about every mod ever mentioned. ( Too much to list - or remember...)
Silver Shadow
Location: Cross the Iron Bridge, turn right off the paved road, go to end of road and honk:South Central KY
Post #7 by Silver Shadow » Fri Mar 23, 2007 11:18 pm
Troubleshooting your auto-trans (C4, C6)...
http://bigblueoval.com/C4_C6_Diagnosis.html
The above goes to a shopping for girl things page. I find nothing about tranmissions.
I do not choose to be a common man;
It is my right to be uncommon if I can
Pastor Butch
'Bless your uneasiness as a sign that there is still life in you.'~Dag Hammarskjald
"To go against conscience is neither right nor safe."~Luther
80broncoman
Re: FAQ/Links.
Post #8 by 80broncoman » Fri Jun 24, 2011 11:00 am
Speedometer Calibration
This is for all Ford trucks at least up to 1994 with electronic speedos
A TSB with all the codes for all three speedo types is posted here 1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net
(From the TSB)
1. Determine which type speedometer/odometer is being installed. The following procedure applies for both "stand-alone" and gauge "cluster" type speedometer/odometer units. (Replacement units are either the 12-switch Beede or the 10-switch Ametek type. The 10-switch Beede has been discontinued for service.)
2. If the unit to be calibrated is a 10-switch type, determine if it is an Ametek or a Beede by looking at the type of electrical connection on the back. The Beede has four (4) "studs", while the Ametek has a single plug-in type connector. If a 10-switch Beede is replaced with a 10-switch Ametek, a simple electrical jumper wire will be included with the new speedometer.
3. There are three speedometer setting charts: Ametek 10-position, Figure 1; Beede 12-position, Figures 2-5; and Beede 10-position; Figure 6.
The info on figureing out which brand speedo you have is NOT in the factory service manual!!!
And the 2nd way to do it for the beede speedos
Them there is this PDF From hanebeede:
http://www.haneline.com/hanebeedeinstruct.pdf
Look at pages 9 and 10 for speedo settings.
Eaton/Roadranger info (mainly for larger trucks)
LiteratureCenterResults
OAPSE Union Member
Real men don't wear Bowties
