90 f150 A/C Delete
Eff1 Shifty
90 f150 A/C Delete
Post #1 by Eff1 Shifty » Sun Apr 13, 2014 8:03 pm
as the title says im trying to "delete" remaining a/c components. i bought the truck without a compressor unfortunately so now im just trying to clean the bay up a bit. i have a few questions though. in the 1st pic circled in red above the a/c accumulator. do i just disconnect that and cap it off?
seemingly more important, in the 2nd picture the a/c hose runs into the radiator. does this just need to be taken off and capped loose? should i use a plastic or rubber cap? not sure if it matters.
imagur
screenshot tool
image sharing sites
MechRick
Re: 90 f150 A/C Delete
Post #2 by MechRick » Tue May 06, 2014 10:04 pm
you could just cap them off, but it would be better to scrounge a non-a/c plenum housing from the junkyard and remove the evaporator and condenser and all the lines for weight savings. You could swap the controls to get rid of the a/c settings too.
Since I'm in Vegas and we see the occasional 117 degree day, I went the other way and added all of the above. My '94 truck's a/c components are swapped from an '86 one. All fits.
Stock cam, aluminum cam gear
Eff1 Shifty
Post #3 by Eff1 Shifty » Mon Mar 06, 2017 7:18 pm
So im wanting to remove my a/c evaporator and the box it sits in. I need to keep the heater blower, and could make some ducting or block off plates. There are 3 holes on the firewall and im wondering which ones I would block. Or the best way of going about it.
Eff1 Shifty
Post #4 by Eff1 Shifty » Mon Mar 06, 2017 7:21 pm
I took a few pics at the junkyard to get an idea of how things look inside the evap box and on the firewall
