PTO mounted on BW 1356 transfer case
crackdhead
Post #1 by crackdhead » Mon Mar 23, 2015 2:20 am
Has anyone actually seen one? I know the bolt pattern is standard and Ive seen gears on ebay but couldnt find any info on one actually mounted...
For the context Id like to run a pto winch out front on my 92 150
Re: PTO mounted on BW 1356 transfer case
Post #2 by bubba22349 » Mon Mar 23, 2015 2:40 am
:hmmm: Mostly they were used in the F350's with 5 speed behind a Diesel and also sometimes you will see them in the F250's
Even a bad day Drag Racing is still better than a good day at work!
Current project is a 1988 John Deere 420 Garden Tractor I need a few small parts to get it fixed, plus some cosmetic items, maybe a few attachments, if you happen to have or know of JD 420 parts would welcome the help!
My Ex-Inline 6 Fleet 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
82F100SWB
Post #3 by 82F100SWB » Fri Apr 10, 2015 1:45 am
You need the F250/350 pto equipped case, you can't bolt a PTO onto your existing one.
96 F350 4x4, CC 7.3/ZF
96 F250 4x4, EC 7.3/ZF
92 W250 4x4, 5.9/G360
90 F350 4x4, C&C 7.3/E4OD
82 F100/86 F250, BBF/T19/1 tons/Boggers...
81 F100/86 F250 6.9/T19
Quite simply, they didn't build 'em like this
It's not what YOU buy, it's what YOU build
sdiesel
Post #4 by sdiesel » Sun Apr 12, 2015 11:05 am
i have a 1356 on the bench right now with a pto port. came from a 350 dually 4x gasser.
all 350 had them and the sno-plow optioned 250 trucks too.
case is different obviously for the opening and there is a pressed on gear for the drive. the shafts may be different too.
chad
Post #5 by chad » Sun Jul 19, 2015 10:36 pm
I had to find out who made the PTO and source parts from them (Konig made mine in '69). A less helpful source may B to contact BW - give them your 1356 number asking for assistance that way. Another idea is a hydrolic winch run off the pto (it drives a hydro pump - my Koenig is mechanical all the way). Lastly some PTOs were mounted on the transmission (NP, ZF) and you may find something that way.
Let us know how U do!
Chad - '70 LUEB on '77 frame (i.e. PS, D44, trapezoidal BB 9", 4.11), '69 250ci, NV 3550 & DSII, "T" D20/PTO, 2" SL, 1" BL, 4 discs, 33"X15", tool boxes, etc. Seeking: Hydraulic gear motor for Koenig pto. chrlsful@aol.com
crackdhead
Post #6 by crackdhead » Sat Jan 09, 2016 2:58 pm
Oooo I kind of forgot about this... But Im almost positive that the PTO flanges are standardized so that brings me to the gear.... Ive seen coarse and fine tooth gears and I dont know which is in the 1356...
I guess my only option is to just go get a 350 tcase and try to put my pto drive on it and see if it has the right pitch gear on it...
Oh yeah i got a t18 trans years back and it had a pto unit on it... Sorry I think i should have started with that...
The real bummer is that I have to get a 350 AND bronco 1356 then slap them together because i want a pto port front case and a slip yoke elminated rear case... I am under the impression only broncos had a fixed rear output
Which kinda makes me worried they had different size parts to account for tolerances like maybe they matched the cases... But I have also heard of them having issues with drive train clunking and it was just a lack of thrust shims in the tcase and the shafts shifting forward and back with no ill effects other than drive train clunking...
chad
PTO mounted on transfer case
Post #7 by chad » Sat Jan 09, 2016 3:23 pm
there were some made specifically 4 the bronk back in the day when the vehicle was new (see the site recommended). They were a lill different than a j**p model (or others, obviously) I have the shafts and everything but the winch & carrier bearing. I got it all shipped from Louseannie and the winch (not needed) was an extra ship expense I did not wish to pay (1500 mi to the Commonwealth of MA). An inspection plate drops offa the bottom and the unit has an open case w/bolt holes matchin the x-fer case's @ that same location. I like it better than the ones mounted on the transmission due 2 more options in feed speed.
crackdhead
Post #8 by crackdhead » Sat Jan 09, 2016 4:15 pm
I think I saw some of the old magazine ads for the koenigs I was actually thinking about trying to get one to use but one day an old holmes wrecker showed up at the junkyard so I grabbed the bed winch for $50. Its huge and only rated for 8k (more like double that from what Ive heard) But i really like it since it has a built in reversal unit and has like 3 or 4 aux shafts... I was actually thinking about just sticking a 2 stage air compressor in the bumper also and just running it off the winch
chad
older model wrecker parts
Post #9 by chad » Sat Jan 09, 2016 4:30 pm
"…3 or 4 aux shafts…"
That's interesting - any pic?
Did U get all the controls too?
The booms B nice in a flat bed to pick up stuff (to carry on the bed or just move).
You're talkin bout the main winch on the wrecker, now, right? Not a lill 1 on the side...
crackdhead
Post #10 by crackdhead » Sat Jan 09, 2016 9:08 pm
Its a holmes 440 mechanical... Back before hydraulic wreckers haha...
I personally dont have a pic but the ones in the top row look like mine https://www.google.com/search?q=holmes+ ... AaihD6g%3D
I dont think they are all aux shafts as at least one should have a brake on it but the brake guts are all rotten out and its a worm screw winch so i dont think i really need it...
At least one spins constant with the pto input and then I think theres 2 more that spin in the direction of the cable drum whether it be forward or reverse which I think are supposed to each have a brake on them but I dont see why they couldnt be repurposed with a pulley or sprocket on them
Only problem really is the size of the thing WAY taller than a regular truck winch
But it has been at least a year since i looked close at it...
chad
Post #11 by chad » Sat Jan 09, 2016 11:21 pm
Thanks for the link.
It sure has a lot of pic. I saw 2 pto units, 1 about 1/2 way down & another just a lill lower - like mine. (The 1st was upside down showin the main gear). Only 1 showin the shafts, U joints, etc of a Koenig like mine.
Also 1 guy (or is it a girl, too sm. a pic 2 C) did what I said - put the derrick (if U will) on his flat bed (the 1 w/the tool box on the tail of the bed/blockin the pic a lill).
These things (wrecker winch) look chain driven (off drive shaft)? The "extra shafts" U mention may just B places to put sprockets for different drive ratios (by moving drive chains to different places on the winch).
crackdhead
Re: PTO mounted on transfer case
Post #12 by crackdhead » Sun Jan 10, 2016 12:23 pm
chad wrote:Thanks for the link.
It was chain driven but I think its because thats the only easy way to move power vertically between 2 parallel shafts I figured Id just put a universal yoke on where the sprocket is...
As for the different ratio sprockets on the shafts I never thought of that... Ill have to rememeber that if i cant get my pto on my bw1356 and am stuck with it transmission mounted
No i didnt get any controls with it... Im pretty sure it was just a single rod going back to the handles on the tail of the wrecker body.... Im kind of disapointed I didnt get the wrecker body and mast considering they said 300 for it with the winch on it(i think its been a year but i remember the bed was reasonable).... But i live in suburbia and wouldnt really have a place to put it and couldnt justify not having a container shaped bed on my 1/2 ton truck
chad
Post #13 by chad » Mon Jan 11, 2016 8:07 pm
"...live in suburbia…"
I hear ya on that.
I got the acreage but it's a steep gradient - covered w/bronk prts
8-0
crackdhead
Post #14 by crackdhead » Tue Jan 12, 2016 9:25 am
That would be pretty sweet though owning a mini crane I hate thinking about stuff I shoulda bought... Just like years back an 80s f350 wrecker for $650(?) needed a clutch... Passed it up What a dummy right? :bang:
chad
Post #15 by chad » Tue Jan 12, 2016 2:16 pm
"...a dummy right?…"
not so sure…they wrk them pretty hard, might have been it's own "wreck" (get it?).
Users browsing this forum: No registered users and 6 guests
