Smog pump delete?
95cranker
Smog pump delete?
Post #1 by 95cranker » Thu Aug 09, 2018 5:27 am
Probably not the first or the last thread that ends up asking this question but will deleting the smog pump be a good idea if it's frozen up?
BigBlue94
Re: Smog pump delete?
Post #2 by BigBlue94 » Fri Aug 10, 2018 12:13 pm
If you don't need it for testing, yes, just remove it and use the eliminator bracket or a shorter belt.
1985 Bronco. 309ci I6, NP435, 4.56 gears, Detroit locker and tru-trac, 4" lift, and 37" swamper tires. The 309 is 9.75:1 CR with a Schneider 140H cam, 4bbl, roller rockers, larger valves, and headers.
95cranker
Post #3 by 95cranker » Sun Aug 12, 2018 1:44 am
Thank you for the reply, by chance do you know what you need to block off all the ports, this is on a 95 4.9
95cranker
Post #4 by 95cranker » Mon Nov 12, 2018 7:24 pm
My truck is almost back together but I can't find a belt that will fit I already took off the pump so does anybody know of a belt that will work?
Thanks in advance :)
Phase3
Post #5 by Phase3 » Tue Nov 13, 2018 11:50 am
My truck has no smog pump im pretty sure the accessories are stock. I use belt 25-060815
Thats for a 4.9
1996 f150 turbo 4.9 OBD2 M5OD 4x4 12 lbs on 93
1997 f350 351w cclb
