New starter issue
RMP6500
New starter issue
Post #1 by RMP6500 » Sun Sep 16, 2018 9:24 pm
Hello everyone! Pretty happy I've found this forum.
So I have a 1994 f-150 with the 4.9 automatic 2wd and loving it! One owner, garage kept and all service records with 135k miles. Anyway, had to replace the starter and when the old one came off, the top bolt came with some shavings from the transmission. So now that bolt will not tighten up.. anyone know if the BH goes all the way through for a longer bolt and lock nut combo? Or if it would be possible to tap / use Heli-Coil without destroying the starter or trans?
Re: New starter issue
Post #2 by bubba22349 » Mon Sep 17, 2018 12:10 am
You should be able to remove the starter and install a hei coil to repair the trans case hole fairly easy. In that way the stock size starter bolts will still work. Good luck :thumbup: :nod:
I am hunting for a cheap project car to build up. My Ex-Fleet of Sixes sadly these are all long gone! :bang: 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
RMP6500
Post #3 by RMP6500 » Mon Sep 17, 2018 9:16 am
Alright I will give it a go when I find some free time. Thanks for the response!
