'54 Ford 4x4 pickup
54-4x4
'54 Ford 4x4 pickup
Post #1 by 54-4x4 » Fri Feb 15, 2019 12:12 pm
I am not sure if this is the correct place to show what I'm up to but if you are interested in what I'm doin' I will try and keep this happening.
To get started with this project a few years ago a friend offered me enough parts from his collection of old Ford pickup trucks to build a truck of my own.We wandered around the bone yard in the back 40 so to speak.A price of 1500 bucks was agreed between the two of us.That would give me any parts I need to build to build something for myself.
We picked a cab and front clip from about 4 or 5 around the same year and he hauled it over to my shop.He seemed more excited than me.Normally I like to build bikes.This is a first attempt to put a truck together from scratch.
I bought a '79 F250 4x4 from my son for 300 bucks.That is the foundation.It was pretty ratted out.He learned how to burn donuts in our field and tortured the truck until it quit.I brought it up the hill to my shop an peeled the body off.The running gear is all good stuff.Dana 60 front and rear with 4:10 gears,205 gear drive transfer case and a 400 with a 4 speed.
I really like 300 sixes so the first thing to go was the 400 V8,then the 4 speed.There are lots of older Ford pickups sitting around in peoples yards rusting away around here.I have been fortunate enough to get most of these old trucks for free just to move them so I have aquired a number of parts vehicles.
The frame now has a 300-6 and a ZF 5 speed tranny that I mated to the 205 transfer case with some careful grinding of the tranny to get them to slide together.The output shaft on the tranny has the same splines as the 205.The grinding was for the shifting of the transfer case to fit the tranny.Because the 5 speed is longer than the old 4 speed I had to move the transfer case frame mounts to the rear a bit.This means I will need to build a couple of drive shafts at some point.I just used the existing engine mounts.The engine seems like it is sitting back a ways to me but I'm OK with that.
Oh ya the tires are 285s X 16".The ones on it are some used ones off my daily driver.That is when I'm not off on my bike somewhere.
At some point I think I will build an aluminum flat deck rather than use a step side box.It will be more useful for me.
Here are a few pictures of how things are looking.
DSCF4210.JPG[/[attachment=0]DSCF4215.JPG
These are the cab mounts.
54-4x4
Re: '54 Ford 4x4 pickup
Post #2 by 54-4x4 » Fri Feb 15, 2019 6:15 pm
This is what the front clip mounts look like below the rad support
one on each side.
54-4x4
Post #3 by 54-4x4 » Fri Feb 15, 2019 6:54 pm
The stuff you see so far I did a couple of years ago.I got the itch to do some travelling around the world on my motorcycle so very little got done as my bike habit takes precedence over the truck.While riding I started to think about this old pelter and decided if I build an engine for it from my 300 stash it will give me some more incentive to get the truck mobile.
The steering was next.I used the the column from the '79.It was not going to work in the original location on this body so I cut a hole in the fire wall and shortened the shaft about 6".I had to drill a new hole and press the pin that holds these two little square blocks that slide around in the connection on the input to the steering box.After mounting the column to the dash and the firewall I was really happy.Now I can move the truck around a lot easier.
I've been lighting a fire in the stove and been working on the project truck almost every day.
I picked up some leather seats at Pick A Part when I was in the city from a Volvo for 50 bucks.They have lots of adjustment and are heated also.It feels like I am really moving ahead getting them mounted.Now that the seats are installed you can see my gear shift for the tranny and transfer case are done too.A friend gave me the stick shift knob.It is part of a draft horse collar called a haimes.It feels just right.
54-4x4
Post #4 by 54-4x4 » Fri Feb 15, 2019 7:06 pm
I have a hydralic clutch on the 5 speed so I used the foot pedals from a later model truck.Lots of foolin' around to get these mounted
These are the pieces I cut from the original setup,then I welded some new gussets to support the pedals to the bottom of the dash
The firewall looked like Swiss cheese after lots of trial and error getting the brake booster and pedals located where I'm happy so I cut a section out and replaced it
The '79 brake booster master cylinder set up
and the clutch and brake pedals
This is as far as I have got.
broncr
Post #5 by broncr » Fri Feb 15, 2019 9:24 pm
I'm getting jealous. Nice pics & documentation - keep it coming, please!
I can't think of a better forum then "The Truck Stop" for the overall project. You might get a bit more collaboration/insight if you have specific Q's about engines, drive trains, etc.. There's quite a volume of knowledge floating around here. I'll be glad to share what little I can.
'82 FSP Bronco. Just about every mod ever mentioned. ( Too much to list - or remember...)
54-4x4
Post #6 by 54-4x4 » Sat Feb 16, 2019 12:07 am
I've been getting some advice on the 300 six performance section.I'm sure something will come up that will need to be addressed.I like doing this as it makes me think.There are lots of ways to skin a cat and more minds make it easier.
54-4x4
Post #7 by 54-4x4 » Sun Feb 17, 2019 7:49 pm
Another good day in the shop for me.I managed to pull a clutch master cylinder from a parts truck,I think an '88 or '89 .That was out in the snow in front of the shop.I need to grab the throttle cable too.Now back in the shop with a small pattern from a piece of old cereal box to cut the hole in the correct spot to install the clutch master cylinder.
You can see there is not much room to get the cap off because of the support for the rod to mount the front clip.I will have to drill another hole and move the rod about a half an inch to gain a bit more clearance.
You can see how tight it is tucked in behind the brake booster.
Also managed to mount the gas pedal after modifying it a bit to fit.
I am going to use the throttle cable and part of the support bracket off the EFI setup.That will make it easier to operate the carb throttle lever.
A little bit every chance I get to work on the old girl and she is starting to feel like I'm getting somewhere now.
54-4x4
Post #8 by 54-4x4 » Sat Feb 23, 2019 6:25 pm
I didn't really like the accelerator pedal.It did not feel right to me so I made a change and cut the arm a bit shorter and made a big foot from a piece of aluminum.Welded a hinge on the bottom and made up a steel bracket that is welded to the floor wth a 1/4" bolt as a pivot.
The EFI throttle cable worked out perfect.The carb needed a bracket built to support and line up the cable and the other end needed a spacer on the fire wall to fit the accelerator properly.Finicky little parts to build.It took me three tries to get things working smoothly.
54-4x4
Post #9 by 54-4x4 » Sat Dec 21, 2019 12:46 pm
Doing a little more work on my ole' project truck.The wheel bearing on the drivers side was a bit loose so I took everything apart.Put new kingpin bushings in and cleaned all the parts.I needed new rotors as they were gouged and thin.Out back of my shop I looked through a selection of old pickups that had been given to me over the years and found a set of hubs that are like new after cleaning them up off an old 3/4 ton that had a diesel in it.The only parts left is the running gear as everything else has been parted out or went to the dump so I lucked out.I bought seals, tie rods bearings and changed over some of the parts.this is where I'm at now.
54-4x4
Post #10 by 54-4x4 » Mon Dec 23, 2019 12:05 pm
Mmmm,for some reason my pictures didn't show up.
65 F-100 pete
Post #11 by 65 F-100 pete » Fri Dec 27, 2019 8:22 pm
Hi '54 Ford 4x4 pick up guy,
You sure have done lots of metal fabing. I especially like your carb. throttle cable, holding clamp. You said you took out the v-8 and put a 300 in. Good choice. I have a 240 in my '65 F-100. It is one sturdy power plant. I put a set of cast iron headers on it back in June. Wow ! It is like where did all the power come from ? Of course, the motor is not nearly as restricted now. Are you going to run headers too ?
All righty then, Cheers, Happy New Year to you and all you love, Pete
65 F-100 pete
Post #12 by 65 F-100 pete » Fri Dec 27, 2019 8:24 pm
Hi again, What type carb. are you using? And intake? Pete
54-4x4
Post #13 by 54-4x4 » Tue Dec 31, 2019 7:28 pm
I have a Offy intake manifold with a 550 Holley and a set of Hooker headers.
autonoob
Post #14 by autonoob » Wed Jun 24, 2020 11:35 pm
Any updates with regards to this restoration project? :?
