Dennis O. Schjeldahl Passed Away July 16th
wsa111
FSP Moderator
Post #1 by wsa111 » Wed Jul 19, 2017 8:32 pm
Dennis was the co-author of the Ford Six Performance Handbook.
He had been fighting cancer for many years. He will be sadly missed.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
Re: Dennis O. Schjeldahl Passed Away July 16th
Post #2 by xctasy » Wed Jul 19, 2017 10:48 pm
May he rest in peace, Bill.
Honour to him.
Adios, Dennis/Hot 6t Falcon!
Dennis Schjeldahl, (say Shell-doll)
Co-Author of The Ford Falcon Performance Handbook
http://www.falcon6handbook.com
Last active, Fri Jul 07, 2017
Last post, Thu Jun 22, 2017, how to start your 144.
What a glorious and sharing man he was.
To
CZLN6,
The other co-author of the Falcon Performance Handbook
David, all my heartfelt condolences. Hope you and your sister are supported in this hard to accept time.
Messages here I guess, Bill, so Davids messages folder doesn't get jammed up.
May the "DOS" Oval be blessed...
viewtopic.php?f=1&t=75757&p=583882#p583882
Hot 6t Falcon wrote:Howdy everyone from the Schjeldahl Brothers!
My brother, Dave, and I have a project head on which we are working. It is a “hex” log D8BE. We have mounted the carb flange on the log - off set to the front. So why do this??? One reason is that it is a good experiment to see if the theory of “the front 3 ports are running leaner than the 3 rear ports during acceleration or even just cruising.”
Another reason, it was a little easier, and therefore cheaper, to slide the carb forward – less welding and flatter to mill smooth. We’ll know more as we get it on the 1978 Mercury Zephyr “Z” and do some testing. Spark plug readings will tell us a lot! So will the stopwatch.
Matt Cox of Vintage Inlines sold us the carb flange, and the 302 one piece valve spring retainers and tubular pushrods for the adjustable rocker arms.
I can’t figure out how to post pictures on the TFFN or FSP. It says to post them to Photobucket??? What’s that??? Do you know how to post pictures to the forums? HELP this Old man.
Pictures:
#1 Shows the #2 intake port. The little screwdriver shows where the threads were for the original one-barrel.
#2 Shows where the second set of threads for the original carb threads were (near the heel of the screw driver.)
#3 Shows the difference between the length of the manifold to the front and the length of the manifold to the rear of the Carb flange.
So why do this??? One reason is that it is a good experiment to see if all the theory of “are the front 3 ports running leaner than the 3 rear ports during acceleration or even just cruising.” Another reason, it was a little easier, and therefore cheaper, to slide the carb forward – less welding and flatter to mill smooth.
My red 1978 Mercury Zephyr “Z” coupe is PS, PB, Auto, AC. I got old, and the Falcon Ranchero from 20 years ago is worn out and too hard to drive. But the stock “smog” 200 Zephyr is just too slow, and the valve stem seals are completely shot. All of the smog equipment has been pulled.
The new carb will be an Autolite 1.14 with .059 jets. The head has 1.5” SSI exhaust valves. The stock diameter intake valves are backcut. The head was milled .065” in anticipation of a thick head gasket. This works out to a 9.0 to 1 compression.
I am also working on using an offset woodruff key in the timing gears… to alter the stock cam timing just a bit. I bought a Mister Gasket Crank/Cam Key 4 degree offset #988G. After I pull the timing chain, and gears set off an extra 1969 M 200 I have, I’ll have a better idea if the key will work. Has anyone else tried this?
The car will NOT have headers. I am seriously considering a small low pressure turbo. No more than 4 lbs. boost. That will have a “J” pipe from the stock exhaust manifold. BUT… this will come a year or so down the road. I have to move the AC compressor first.
Dennis Schjeldahl (say shell-doll)
Post #3 by bubba22349 » Thu Jul 20, 2017 8:24 am
Sorry to hear that Bill, my condolences to CZLN6 and their family members.
I am hunting for a cheap project car to build up. My Ex-Fleet of Sixes sadly these are all long gone! :bang: 1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
ledslinger29
Post #4 by ledslinger29 » Thu Jul 20, 2017 2:32 pm
Prayers and good wishes David.
68 Bronco Halfcab 170 wallered out .060 over, oversized valves, zero decked, 9:1 SCR, Autolite 1100 w/ Loadomatic/Pertronix, Schneider 248/56H cam
woodbutcher
Post #5 by woodbutcher » Thu Jul 20, 2017 7:01 pm
:( Condolences to both families.God bless ya.
Leo
Otto von Bismarck
rbohm
Assistant Admin
Post #6 by rbohm » Thu Jul 20, 2017 7:18 pm
fair winds and following seas dennis.
david, my condolences to the loss of your brother.
64 falcon
66 mustang
05 grand marquis
transient nodes of thought
of invention
bmbm40
Post #7 by bmbm40 » Thu Jul 20, 2017 8:31 pm
So very sorry to hear of this loss to David and the families. Dennis Schjeldahl will be missed.
NEXT- direct mount 2v, power brakes, rear LS, 3G, electric fan, electric upgrades, custom curved DSII, header, 31" tires
62Cometman
Post #8 by 62Cometman » Fri Jul 21, 2017 3:07 pm
its a sad time in the ford six world so much knowledge and history lost when a great man dies, a lifetime of experience and understanding that can never truly be passed on. He will be missed and remembered anytime a ford six roars to life.
1962 Mercury Comet 170 ci, Dagenham Trans, 2.83:1 7.25 rear.
She ain't fast but she's fun. 8)
drag-200stang
Post #9 by drag-200stang » Sat Jul 22, 2017 10:15 pm
So sorry to hear about Dennis passing. My condolences to the family.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
gus91326
Post #10 by gus91326 » Sun Jul 23, 2017 5:13 pm
Terrible news. His knowledge will be missed. Condolences to his family.
