The new OLD FTF gets a "Duesenberg DOHC 4-valve"
- THE FRENCHTOWN FLYER
- VIP Member
Re: The new OLD FTF gets a "Duesenberg DOHC 4-valve"
I haven't run mine. I filled the corner fillets with weld so it matches up to the port. Mismatch is not a good thing. I doubt if a streeter would see a noticeable difference though.
- Registered User
You just filled the last half inch or so and then ground them to transition them into the head? You didn't/weren't able to fillet the entire things were you??
- VIP Member
That's right. I like to weld the ends of runners on each side to minimize the chance of cracking.
Great work FTF love reading your posts.
Please keep the updates coming.
Merry Christmas to you and yours.
rikard aka Rick
rikard aka Rick
"If women don't find you handsome they should find you handy" Red Green
Now-95 Black F150 XLT SC 300 5 Speed " Nelly Belle"
Past I6s
250 Chrysler Spitfire, 194, 250 Chevy, 223 Ford, 242,258 AMC, 225 Slant 6, 330 REO GC
Past I6s
- Registered User
Hi FTF, Looks good! Got any calveskin gloves to go with the goggles & the hat? Just out of curiosity, What kind of radiater are you going to run? Maybe slanted with an electric fan? What kind of front axle is that I'm guessin mid to late 50's Truck? What's the wheelbase? Just for fun maybe the next project could be a v-12 "Forderarri". You do brilliant work sir. I can't wait to see it boil water!
- VIP Member
I built the grill shell to hold a '64 Mustagn radiator with an electric fan. I may use a mechanical fan if there is enough room - to make it look more period correct.
The axle is indeed a '53 Ford truck, narrowed 6 inches, smoothed and drilled full of lightening holes. While most cars of that era ran only rear brakes operated by a hand lever I am going to run front and rear brakes operable by either the outside hand brake lever or a foot pedal inside the car.
I hope to get an old pilots skull cap, goggles, an old polo stlye helmet and a pair of gauntlet gloves for photo ops.
(For hot laps its a fire suit and Simpson safety equipment tho.)
I forgot the wheelbase - around 111" I think.
- VIP Member
After another winter hiatus I am back on the "speedracer" project. I am doing the steering drag link and associated stering nacelle to conceal the pitman arm:
- VIP Member
- VIP Member
I made these strips to hold on the body panels. Way back when the body panels were usually held in place with angle flanges riveted to the edges of the panels. Now it would be soooo much easier to attach them with quarter-turn Dzus buttons but to stay close to original I just embossed rivet heads on the flanges and will spot weld them on to the body.
- VIP Member
I placed all the semi-finished panels on the chassis to mount the body to the frame using the flanges, like they used to.
- bubba22349
- Global Moderator
I am still hunting for a project car to build but with my current low budget it's not looking so good. My Ex- Fleet of Sixes these are all long gone!
1954 Customline 223 3 speed with O/D, 1963 Fairlane project drag car with BB6, 1977 Maverick 250 with C4, 1994 F-150 a 300 with 5 speed.
- Registered User
What a wonderful project! Thanks for sharing with us.
FTF it time for some 15 inch dirt tires on the back and 10 inch on the front and a fairly stock motor because with all the torque a 300 makes it will still spin the tires off the corner
99.5 F350 lowered air ride strong PSD crew cab swb
48 ford coupe cage old school stock car 12.25 to 1 290 cilford cam, cliford 2x2 with webber 38/38,some cool old stock car headers, 240 head with big valves, bbc roller rockers
- VIP Member
I agree. Aside from the side draft carbs and the exhaust system and a set of hypereutectic pistons and the crossflow head the engine will remain basically stock, including the stock camshaft for lots of tire wrenching torque and a tractible idle slow enough to be driven in parades and parade laps.
Even so, I expect it will put out more power than the typical Miller or Offy of that era.
I am looking at skinny Coker dirt tires and wire wheels. Some things I've heard about some Coker tires (mostly their whitewalls) are a bit unsettling, but other vintage tire makers like Diamondback do not offer dirt tires. Dayton wire wheels are too pricy for my budget - about 2 grand a wheel! - and Coker wires fit my drums.
forget the wires big Weld sprint car wheels or wide five with some big Hoosier
- Registered User
Wow! congrats FTF, a magazine car! If anyone is interested FTF's Duesenberg has been published in the latest issue of Street Rodder magazine.
- VIP Member
Thank you chessterd,
I knew it was coming but I'm travelling now - I'll check it out when I return home.
Its only a subject for Professor Hammer's column on shaping metal. Someday I'd love to see a feature done on it after I complete it. I'd better get humpin'.
I never posted on this thread.
I have been watching this for years though - so cool.
Would you be willing to share some pics of the 3 carb manifolds as you were doing them?
- VIP Member
Greg D wrote:I never posted on this thread.
Thanks Greg D.
Did you mean the 2 x 1 intake on this build, the 3 x 1 build from three stock intakes, the EFI based 2 x 2 intake or one of my 3 x 2 race manifolds?
- Registered User
WOW those are some long drag links hanging out the side. also same, been watching this thread for as long as I can remember and that's really beautiful, FTF.
What is that head, and where did you get it? I noticed that it has the Ford casting marks on it; so its not one of these chopped up and welded together heads.
I mainly ask this because Im planing a very high HP build for my 93 300 and am trying to look for all types/options of crossflow options.
(Excuse my ignorance Im relatively new to this forum and haven't been through all the great info on here)
That's an ultra rare ford crossflow only a few ever made if I remember rite less than 100. Good luck finding one the last one I saw was on eBay and a reserve not at $1500
Any updates?
James - '62 Ranchero (200cid), '71 LeSabre (464cid)
The ONLY safety device we need is a 6" sharpened steel spike bolted to the center of the steering wheel of EVERY vehicle.
Emergency Rooms and Funeral Homes will be busy for a week or so, then I predict a dramatic drop in vehicle accidents.
- VIP Member
I did a little more work on the head rest. I think it looks too big and I'll make it lower and shorter.
- VIP Member
Hey, I just realized this thread has been moved over to this forum - I thought it had been deleted somehow. I'm in SoCal taking a little break but when I return I'll post an update.
THE FRENCHTOWN FLYER wrote:Hey, I just realized this thread has been moved over to this forum - I thought it had been deleted somehow. I'm in SoCal taking a little break but when I return I'll post an update.
First time I've seen this one! Come'on back... I'd love to see any progress!
See all my cars here: Pikesan's Garage What's in your garage?
- VIP Member
I have a much more detailed build thread over on Jalopy Journal's H.A.M.B. bulletin board:
http://www.jalopyjournal.com/forum/thre ... 98/page-10
The champ car came back to my home shop today, reunited with the '46 Ford push / tow truck and its own trailer. This build has been going on a long time, but the truck and trailer got finished in the mean time so I suppose that signifies some progress of sorts. Stay tuned.
- VIP Member
In these old replicas there are a lot of little "visual delights" that can make a car interesting to see. I thought I would make one of those little visually appealing details today. A heat shield for the exhaust pipe. First I cut a blank of sheet stainless, laid out some cooling holes and rolled a curve in it. Then I made a small belling tool for my DiAcro press so I could put a bell mouth on the holes. This is needed to prevent the shield from becoming a cheese grater on my body parts should I come into contact with it during an upset. I just need to make some stand-off nuts to weld it in place when the time comes.
- VIP Member
I did some more shaping on the tail section. Its almost ready to baptize in bondo. Attaching the mounting flanges comes next.
- Registered User
That's way to pretty to cover in bondo. It sure would look good polished.
Nice work
- bubba22349
- Global Moderator
By "THE FRENCHTOWN FLYER" My old topic got "locked". As I have a lot more left to do I'll start another one. As luck would have it this summer I'm building the "mule" engine for it, along with another U-flow engine for my son's Anglia, on which I may start another thread if time permits.
This week I started on the head:
the intakes get a 30 deg. back cut
ready for reassembly
The full build story is on the H.A.M.B.:
https://www.jalopyjournal.com/forum/thr ... ct.223598/
