<<< New Site Update >>>
The new OLD FTF gets a "Duesenberg DOHC 4-valve"
THE FRENCHTOWN FLYER
Re: The new OLD FTF gets a "Duesenberg DOHC 4-valve"
Post #201 by THE FRENCHTOWN FLYER » Thu Dec 20, 2012 10:55 pm
I haven't run mine. I filled the corner fillets with weld so it matches up to the port. Mismatch is not a good thing. I doubt if a streeter would see a noticeable difference though.
clintonvillian
Post #202 by clintonvillian » Fri Dec 21, 2012 8:01 am
You just filled the last half inch or so and then ground them to transition them into the head? You didn't/weren't able to fillet the entire things were you??
Post #203 by THE FRENCHTOWN FLYER » Fri Dec 21, 2012 2:24 pm
That's right. I like to weld the ends of runners on each side to minimize the chance of cracking.
rikard
Post #204 by rikard » Mon Dec 24, 2012 2:23 pm
Great work FTF love reading your posts.
Please keep the updates coming.
Merry Christmas to you and yours.
rikard aka Rick
"If women don't find you handsome they should find you handy" Red Green
Now-95 Black F150 XLT SC 300 5 Speed " Nelly Belle"
Past I6s
250 Chrysler Spitfire, 194, 250 Chevy, 223 Ford, 242,258 AMC, 225 Slant 6, 330 REO GC
chessterd5
Post #205 by chessterd5 » Sun Feb 17, 2013 9:02 pm
Hi FTF, Looks good! Got any calveskin gloves to go with the goggles & the hat? Just out of curiosity, What kind of radiater are you going to run? Maybe slanted with an electric fan? What kind of front axle is that I'm guessin mid to late 50's Truck? What's the wheelbase? Just for fun maybe the next project could be a v-12 "Forderarri". You do brilliant work sir. I can't wait to see it boil water!
Post #206 by THE FRENCHTOWN FLYER » Mon Feb 18, 2013 11:06 am
I built the grill shell to hold a '64 Mustagn radiator with an electric fan. I may use a mechanical fan if there is enough room - to make it look more period correct.
The axle is indeed a '53 Ford truck, narrowed 6 inches, smoothed and drilled full of lightening holes. While most cars of that era ran only rear brakes operated by a hand lever I am going to run front and rear brakes operable by either the outside hand brake lever or a foot pedal inside the car.
I hope to get an old pilots skull cap, goggles, an old polo stlye helmet and a pair of gauntlet gloves for photo ops.
(For hot laps its a fire suit and Simpson safety equipment tho.)
I forgot the wheelbase - around 111" I think.
Post #207 by THE FRENCHTOWN FLYER » Wed Apr 17, 2013 11:13 am
After another winter hiatus I am back on the "speedracer" project. I am doing the steering drag link and associated stering nacelle to conceal the pitman arm:
Post #208 by THE FRENCHTOWN FLYER » Fri Apr 19, 2013 12:37 pm
Today I made a push-off board for the truck:
Post #209 by THE FRENCHTOWN FLYER » Mon May 13, 2013 12:11 pm
I made these strips to hold on the body panels. Way back when the body panels were usually held in place with angle flanges riveted to the edges of the panels. Now it would be soooo much easier to attach them with quarter-turn Dzus buttons but to stay close to original I just embossed rivet heads on the flanges and will spot weld them on to the body.
Post #210 by THE FRENCHTOWN FLYER » Fri Jul 12, 2013 12:48 pm
I placed all the semi-finished panels on the chassis to mount the body to the frame using the flanges, like they used to.
Post #211 by bubba22349 » Fri Jul 12, 2013 4:57 pm
:beer: it's looking great!
1986F150six
Post #212 by 1986F150six » Mon Jul 15, 2013 12:02 pm
What a wonderful project! Thanks for sharing with us.
Lagerhead
Post #213 by Lagerhead » Thu Oct 03, 2013 1:21 pm
FTF it time for some 15 inch dirt tires on the back and 10 inch on the front and a fairly stock motor because with all the torque a 300 makes it will still spin the tires off the corner
99.5 F350 lowered air ride strong PSD crew cab swb
48 ford coupe cage old school stock car 12.25 to 1 290 cilford cam, cliford 2x2 with webber 38/38,some cool old stock car headers, 240 head with big valves, bbc roller rockers
Post #214 by THE FRENCHTOWN FLYER » Thu Oct 03, 2013 11:00 pm
I agree. Aside from the side draft carbs and the exhaust system and a set of hypereutectic pistons and the crossflow head the engine will remain basically stock, including the stock camshaft for lots of tire wrenching torque and a tractible idle slow enough to be driven in parades and parade laps.
Even so, I expect it will put out more power than the typical Miller or Offy of that era.
I am looking at skinny Coker dirt tires and wire wheels. Some things I've heard about some Coker tires (mostly their whitewalls) are a bit unsettling, but other vintage tire makers like Diamondback do not offer dirt tires. Dayton wire wheels are too pricy for my budget - about 2 grand a wheel! - and Coker wires fit my drums.
Lagerhead
Post #215 by Lagerhead » Mon Oct 14, 2013 8:49 pm
forget the wires big Weld sprint car wheels or wide five with some big Hoosier
chessterd5
Post #216 by chessterd5 » Fri Nov 01, 2013 8:50 pm
Wow! congrats FTF, a magazine car! If anyone is interested FTF's Duesenberg has been published in the latest issue of Street Rodder magazine.
Post #217 by THE FRENCHTOWN FLYER » Sat Nov 02, 2013 5:13 pm
Thank you chessterd,
I knew it was coming but I'm travelling now - I'll check it out when I return home.
Its only a subject for Professor Hammer's column on shaping metal. Someday I'd love to see a feature done on it after I complete it. I'd better get humpin'.
Greg D
New Member
Post #218 by Greg D » Tue Nov 12, 2013 9:29 pm
I never posted on this thread.
I have been watching this for years though - so cool.
Would you be willing to share some pics of the 3 carb manifolds as you were doing them?
Post #219 by THE FRENCHTOWN FLYER » Wed Nov 13, 2013 9:37 am
Greg D wrote:I never posted on this thread.
Thanks Greg D.
Did you mean the 2 x 1 intake on this build, the 3 x 1 build from three stock intakes, the EFI based 2 x 2 intake or one of my 3 x 2 race manifolds?
herosandwich
Post #220 by herosandwich » Thu Nov 14, 2013 8:11 am
WOW those are some long drag links hanging out the side. also same, been watching this thread for as long as I can remember and that's really beautiful, FTF.
henline6
New Member
Post #221 by henline6 » Thu Mar 20, 2014 1:06 am
What is that head, and where did you get it? I noticed that it has the Ford casting marks on it; so its not one of these chopped up and welded together heads.
I mainly ask this because Im planing a very high HP build for my 93 300 and am trying to look for all types/options of crossflow options.
(Excuse my ignorance Im relatively new to this forum and haven't been through all the great info on here)
Lagerhead
Post #222 by Lagerhead » Sat Mar 22, 2014 11:58 am
That's an ultra rare ford crossflow only a few ever made if I remember rite less than 100. Good luck finding one the last one I saw was on eBay and a reserve not at $1500
jamyers
Post #223 by jamyers » Tue Apr 21, 2015 1:53 pm
Any updates?
James - '62 Ranchero (200cid), '71 LeSabre (464cid)
The ONLY safety device we need is a 6" sharpened steel spike bolted to the center of the steering wheel of EVERY vehicle.
Emergency Rooms and Funeral Homes will be busy for a week or so, then I predict a dramatic drop in vehicle accidents.
Post #224 by THE FRENCHTOWN FLYER » Sun Nov 29, 2015 11:01 pm
I did a little more work on the head rest. I think it looks too big and I'll make it lower and shorter.
Post #225 by THE FRENCHTOWN FLYER » Tue Nov 08, 2016 9:55 am
Hey, I just realized this thread has been moved over to this forum - I thought it had been deleted somehow. I'm in SoCal taking a little break but when I return I'll post an update.
pikesan
Post #226 by pikesan » Tue Nov 08, 2016 3:44 pm
THE FRENCHTOWN FLYER wrote:Hey, I just realized this thread has been moved over to this forum - I thought it had been deleted somehow. I'm in SoCal taking a little break but when I return I'll post an update.
First time I've seen this one! Come'on back... I'd love to see any progress!
See all my cars here: Pikesan's Garage What's in your garage?
Post #227 by THE FRENCHTOWN FLYER » Thu Nov 10, 2016 9:06 pm
I have a much more detailed build thread over on Jalopy Journal's H.A.M.B. bulletin board:
http://www.jalopyjournal.com/forum/thre ... 98/page-10
The champ car came back to my home shop today, reunited with the '46 Ford push / tow truck and its own trailer. This build has been going on a long time, but the truck and trailer got finished in the mean time so I suppose that signifies some progress of sorts. Stay tuned.
Post #228 by THE FRENCHTOWN FLYER » Wed Nov 30, 2016 3:56 pm
In these old replicas there are a lot of little "visual delights" that can make a car interesting to see. I thought I would make one of those little visually appealing details today. A heat shield for the exhaust pipe. First I cut a blank of sheet stainless, laid out some cooling holes and rolled a curve in it. Then I made a small belling tool for my DiAcro press so I could put a bell mouth on the holes. This is needed to prevent the shield from becoming a cheese grater on my body parts should I come into contact with it during an upset. I just need to make some stand-off nuts to weld it in place when the time comes.
Post #229 by THE FRENCHTOWN FLYER » Mon May 29, 2017 6:40 pm
I did some more shaping on the tail section. Its almost ready to baptize in bondo. Attaching the mounting flanges comes next.
67Straightsix
Post #230 by 67Straightsix » Tue May 30, 2017 1:02 am
That's way to pretty to cover in bondo. It sure would look good polished. :lol: Nice work :thumbup:
Post #231 by bubba22349 » Wed May 23, 2018 8:14 pm
By "THE FRENCHTOWN FLYER" My old topic got "locked". As I have a lot more left to do I'll start another one. As luck would have it this summer I'm building the "mule" engine for it, along with another U-flow engine for my son's Anglia, on which I may start another thread if time permits.
This week I started on the head:
the intakes get a 30 deg. back cut
ready for reassembly
The full build story is on the H.A.M.B.:
https://www.jalopyjournal.com/forum/thr ... ct.223598/
