The video works...Good deal!!
Gerry Lutz Jr.":37gna995 said:
i'll be the optimist here 13.8 then again the realist in me kicks in
You should have stayed optomistic!!
boston774":37gna995 said:
(sound of rocks grinding...)
That's not coming from your head,
thats what detonation sounds like at 25 psi!!!!!
Hahhaha!
Compression is very low in a couple of cylinders.........
Here is the plan for "Version 1.3"
1) Disassemble current engine
2) Replace burnt pistons with good stock cast pistons from engine #2
3) Port head a little bit
4) Add (actually "finish") alcohol injection system
5) Reassemble and make another attempt on its life!!
In the Meanwhile...........
"Version 2.0" gestation begins....
1) Block honed for forged pistons, decked to .000" (main studs??)
2) forged pre-'74 "C3xx" rods NEEDED ( SOMEBODY PLEASE HELP!! )
3) Fully ported head, stainless valves, head studs - carb mounting modded for 2 bbl.
4) FSPP cam, 214/214 @ .050"
Hmmm.....am I missing anything?
