RichCreations
Fully balanced rotating assembly, back from the shop:
chad":lla021mb said:just from lookin I'd say that's not stroked!
Nice 'square motor' !!!
Is the efi for maintenance? performance 2 match the turbo?
boost is on the lower end ? (sorry, if stated I've 4gotten).
RichCreations":3093rg3g said:Fully balanced rotating assembly, back from the shop:
I Don't understand?bmbm40":2thodt89 said:Plaza Machine?
bmbm40":1afgnrbt said:Plaza Machine in Reno. Are they still there? My friend used to take all his work there.
bmbm40":r4hx2wuk said:Oh sorry, for some reason I thought you were in the Reno/Sparks area.
That is an impressive engine build for your Econoline by the way. Very high tech with EFI, turbo and advanced ignition system I don't recall seeing that combination on another vehicle. Might start a trend.
drag-200stang":1jpzun0o said:If you were building a mostly on boost ,higher psi engine I would say do not bother with deck but you are not.
