Are there gains with a stock motor and MS?
Wesman07
1K+
Supporter 2020
Approved Vendor
I've been looking at the Stinger Pimp set up for my 90 ish stock 300. I was planning on learning how to use the program before I make any motor changes..... and then it got me thinking. Are there any gains to be had with basically a MS2 and wide band ALONE???
Yes
A system that uses a wide band O2 can operate closed loop over the entire load range so the A/F can stay optimized.
You also get to optimize the ignition timing for your fuel octane and running load.
